Plunge routers/bases ?, HP questions - Router Forums
 15Likes
post #1 of 19 (permalink) Old 01-08-2018, 11:22 AM Thread Starter
First Name: Graham
Default Plunge routers/bases ?, HP questions
In my recent [need new router fast] post every one was insistent about the need for a plunge base. I have never owned a plunge router though I have used a few.
I have al ways found them to be awkward and poorly balanced with generally worse depth control than a fixed base. Granted that the last router that bought until now was about 199O, maybe the have improved. But I really fail to see the utility for general routing tasks. I use my routers for edge profiling, slotting, dadoes, template work and mortise and tennons. I can see the utility for sign making but can't think of many other real uses and none that would outweigh the balance, complexity and other issues.
My other question is in regard to large routers and horsepower. I used to have a three horsepower rated Bosch and see that many suggest the large horsepwer routers for tables. I've always used 1 3/4- 2 hp routers in my tables with no problems even with fairly heavy cuts in hardwoods. to the best of my knowledge a 15 or 2 amp circuit at 11O volts CANNOT produce 3+ horse power until the rotor locks up and melts.
And yes there is a difference between hp and torque and even my 1 1/2 hp shaper will out perform any router I've ever used or seen as far as eating wood. but that another whole discussion as they are different tools that have overlapping applications.
Graham O
Who is somewhat long winded
Graham O is offline
post #2 of 19 (permalink) Old 01-08-2018, 12:44 PM
JOAT's Avatar
First Name: Theo
I didn't say that, honest. I can see some uses for a plunge router, even tho I don't own one, and have never used one. For what I do a plunge router would just be a waste. I've got some old Craftsman routers, all low horsepower, and only used in my table, they do what I want, I'm happy. I do have a project in mind that, if I am able to carry it out, I believe a plunge router would be appropriate. But I will give it a shot with one of my fixed base routs before spending any $ on a plunge router. I say, give a new plunge router a test drive, if you like it, maybe you will want to get one. If you don't like it, at least now you will know for sure.
JOAT is online now
post #3 of 19 (permalink) Old 01-08-2018, 12:53 PM
Semipro's Avatar
First Name: John_*
Graham
I think you maybe misunderstanding nothing wrong with a smaller router in a table but them big 3 hp routers are heavy for hand held use, also the newer plunge routers in the 2 hp range are easy to use, I usually recommend to new woodworker that if they can only afford one router go plunge, the best bet is to buy a combo kit with both.
But if you are only using it for edge routering you would have no need for a plunge router
Semipro is offline
post #4 of 19 (permalink) Old 01-08-2018, 12:57 PM
DonkeyHody's Avatar
First Name: Andy
I have 6 routers, only one of which is a plunge router. I don't use the plunge capability very often, but when I do, I'm glad I've got it. You can make do without a plunge base for a long time, but sooner or later, if you get serious about woodworking, you'll need one. Your cheapest way to get both is to buy the kit with both plunge and fixed bases.
DaninVan, Herb Stoops and ggom like this.
We should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore. - Mark Twain
DonkeyHody is offline
post #5 of 19 (permalink) Old 01-08-2018, 01:22 PM
MT Stringer's Avatar
Honestly, I have never had any problem with the plunge base on the Bosch 1617.
There have been times when I needed to make a minute adjustment in the depth. A feeler gauge and .010 made the depth just right. Much easier than the fixed base.
Cutting dadoes that require three passes to get a 3/8 depth, or even 1/4 inch? Just set your depth and make a pass, flip the turret to the next setting and make another pass. Cuts 1/8th on each pass.
Making a stopped dado. Just stop the router movement, depress the handle and the router will raise up out of the dado, then shut it off.
Geevesmac and ggom like this.
MT Stringer is online now
post #6 of 19 (permalink) Old 01-08-2018, 02:59 PM
What Andy said. I wouldn't have tried doing the the juice channels on my Xmas cutting boards with anything other than my plunge router.
Having said that, I would have preferred to use the lighter 1617 rather than the 1619 but I left ordering the plunge base for the 1617 too late. In any case I still did it in two passes just in case I screwed up...
DaninVan is online now
post #7 of 19 (permalink) Old 01-08-2018, 03:12 PM
Like Mike said, stopped grooves or dadoes should be plunged. You say you are making mortises with a router? You should be plunging those too. Not only is plunging them more accurate, it's a lot safer too.
There is no comparison from a 3 horse, 240 volt Baldor or Leeson and a supposedly 3hp router. One horsepower is 746 watts so 3 times that is over 2200 watts and there probably needs to be some room for the surge when it starts. Router makers use a complex formula that involves peak power or brake horsepower but those aren't real measures of the tools ability to do work. But since all manufacturers are lying more or less equally then the HP rating can prove useful in comparing one model to another but I certainly wouldn't buy one router just because the maker says it is 1/4 hp more powerful that it's competitor and if possible use a wattage rating instead, preferably the output rating.
post #8 of 19 (permalink) Old 01-08-2018, 04:27 PM Thread Starter
First Name: Graham
I can see the utility of a plunge in some circumstances such as a captured dado or groove though I have always used other methods. I use a palm router to cut mortice and tenon joints [usually]with a starting hole for the mortice as a full size router would be awkward to use with my jig or I use the morticer and table saw or shaper for tenon's. I have made solid would boxes but used a sled to hollow them out.
I did have one very large router many years ago that used an overhead tether suspension and was I believe two hp but was i think three phase and weighed all of probably 3O pounds. I never dared to use it[I had a greater sense of self preservation back then].
Yes like a 5 hp shop vac or my craftsman 7 hp air compressor. I guess i will have to check the actual amp draw of my 2 1/4 hp machine under load.
Graham O
Graham O is offline
post #9 of 19 (permalink) Old 01-08-2018, 05:13 PM
"I guess i will have to check the actual amp draw of my 2 1/4 hp machine under load."
-Graham
Or not worry about it...
Just from usage I can tell you my Bosch 1619 is a workhorse and is considerably more powerful under full load, than my 1617.
Don't really care myself, what the stats are for either; they're both fine machines.
post #10 of 19 (permalink) Old 01-08-2018, 07:04 PM Thread Starter
First Name: Graham
I had to check on owwmwher someone had athread about large routers and indeed i found the one that i had it was a stanley and they were 3 phase 36O cycle and came in 4 and 8 real not peak hp. for anyone interested search "massive stanley routers" on owwm.org.
Graham O
Graham O is offline
Bench Dog Hole Bit: 3/4" plunge (long)??? BigJimAK Router Bits - Types and Usage 10 04-11-2011 08:18 AM
Old Stanley plunge router info request cw5746 Portable Routing 1 01-28-2011 07:07 PM
plunge router? gweissbock Tools and Woodworking 5 07-31-2008 10:52 PM
Inlay questions (plunge base?) Nickbee Guide Bushings and Templates 2 07-26-2008 03:05 AM
Freud 2200E -- How do I set it up for a measured depth plunge cut? Ladd General Routing 8 11-12-2007 03:23 PM
