Cordless routers for round overs - Router Forums
 5Likes
post #1 of 14 (permalink) Old 01-18-2018, 05:52 PM Thread Starter
First Name: Michael
Default Cordless routers for round overs
I’m looking at having a couple dedicated palm routers for round over work. 1/16” and 1/4”. I use them quite a lot and want to have dedicated ones with zero tolerance bases. Has anybody used the new cordless routers for these small load operations? I have the Milwaukee cordless system. I wrote them and they answered they have no plans on coming out with a cordless router. Probably the only tool they haven’t made cordless. Don’t really want to invest in a new battery system, but I’m still interested in their performance. Not expecting them to be power horses, but just used for round over work maybe they’re good.
MGildersleeve is offline
post #2 of 14 (permalink) Old 01-18-2018, 06:09 PM
DonkeyHody's Avatar
First Name: Andy
I've had somewhat the same thoughts. However, I haven't bought a cordless router because:
1. Unlike my cordless drills, I only use routers in the shop.
2. Like you, I would have to buy a whole battery system.
3. Batteries die. They last longer than they used to, but eventually, they die. I've thrown away 5 cordless drills because the batteries wouldn't take a charge anymore and a new kit cost only a little more than replacement batteries.
Something else to think about . . . suppose you had several tools that all use the same battery pack. When the batteries go, you have more tools to buy new.
I'd like to have a cordless router, I just can't get past the price of convenience. Maybe if I was making some money at it . . . .
harrysin and Roy Drake like this.
DonkeyHody is offline
post #3 of 14 (permalink) Old 01-18-2018, 07:48 PM
JOAT's Avatar
First Name: Theo
Like Andy said. The only battery powered tools I have are the remotes for my TV and air conditioning. I don't use power tools outside the shop, and can't justify the expense and hassle of battery powered tools. I pick up a tool, pull the trigger, and as long as it is plugged in it works, no batteries to charge, no batteries to buy. And the initial expense of corded tools is much lower. Both my sons have cordless tools, but they also both work on job sites where there is often no power, so battery tools are a must for them. For me, no cordless tools works just fine. I think I've got 4 drills, the oldest was bought in 1975/76, and still works. The others were all given to me, and all work. I may buy a cordless saw sometime in the future tho. The reason is, I believe I have found a source for free plywood, from sheets that were CNC routed, with large portions of the sheets not cut. I would have to load them myself, and anymore that is a real hassle doing something like the, hence the saw. I can cut the sheets apart and load the pieces easily enough. And the pieces will be big enough I can make a lot of my own stuff from them.
But, your money, you want cordless, go cordless.
harrysin likes this.
JOAT is offline
post #4 of 14 (permalink) Old 01-18-2018, 09:45 PM
First Name: Roger
I have the whole setup of the Craftsman C3 series including Drill, Hammer-Drill, 2 1/2" Planer, 5" & 7 1/4" Skill Saw, Jig Saw, Saws-all, 1/2" impact wrench, Router and Florescent light. The only problem I've had was NiCad Battery's they are crap and don't last. Once I replaced the battery's with Lithium/Ion they are great. I built a shed using saws drill Router and the XCP and small battery lasted all day. The Router only has a 1/4" chuck but works for round overs and hinge mortising great. I bought my son a starter set and the drill is not as heavy duty or nice as mine. Overall I love the convenience of not dragging a cord everywhere.
Roger0220 is offline
post #5 of 14 (permalink) Old 01-18-2018, 11:29 PM
hawkeye10's Avatar
First Name: Don
Michael don't pay to much attention to what that person said about not coming out with a cordless router. I am not saying they lied but they could bring one out next week and most employees would not know about it.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 14 (permalink) Old 01-19-2018, 04:36 AM
Country: France
First Name: Gérard
Hello!
Cordless means battery , short lives,
Max is 1000 cycles , usual is around 500 cycles ,
very expensive to replace.
Hello Michael !
Rounding over with cordless, Ok.
And what about dust extraction, that’s not a cord but big pipe.
Some extraction systems use a pipe plus electric cable
that is suspended to an arm , above the working place.
Hello JOAT:
To Use around a car, or van: an inverter, gasoline operated:
https://www.homedepot.com/p/Ryobi-Bl...0BTA/300347426
Big choice, some cheaper ones:
https://www.homedepot.com/b/Outdoors...s/N-5yc1vZcbpx
A 400w circular saw is big enough for panel cutting.
(Milwaukee got beautiful little saws.)
Regards.
Regards
ggom is offline
post #7 of 14 (permalink) Old 01-19-2018, 12:22 PM
JOAT's Avatar
First Name: Theo
If I ever get to the point where I need a portable generator I'll just make one. No, Harbor Freight has a cordless sabre saw cheap, it will do for what I would want it for. And that would be cutting thru the small parts of sheets like this, to make small portions I can easily lift into my truck.
JOAT is offline
post #8 of 14 (permalink) Old 01-19-2018, 12:37 PM
TWheels's Avatar
@MGildersleeve , I fully understand the usefulness of a cordless trim router; I am looking into getting one myself. For the naysayers, one additional use for such a tool is mortising a door frame. Everything said about the batteries, dust extraction, etc. is true and are good points.
For a while the Router Workshop (a no longer shown but available online with a subscription, and the inspiration or whatever for this RouterForums https://www.routerworkshop.com/watch-online.html) used a cordless router but I do not remember either the brand or season(s). That router may have been a more powerful but i cannot find anything currently available other than trim routers. Amazon has several brands https://www.amazon.com/s/?ie=UTF8&ke...l_8sjyce9s4u_b.
FYI I strongly suggest avoiding NiCad battery systems because of the toxicity of Cadmium after disposal of the battery; Lithoum Ion batteries seem to be the best choice at the present time
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #9 of 14 (permalink) Old 01-19-2018, 12:50 PM
Country: France
First Name: Gérard
Hello JOAT !
It happened to me to buy long steel bars that would not fit a van.
I just asked "how if i plug my grinder here ?"
"Yep, no problem!"
So all I needed was to bring my tools and a line extension.
Regards.
Gérard.
ggom is offline
post #10 of 14 (permalink) Old 01-19-2018, 04:16 PM Thread Starter
First Name: Michael
Thanks, guys. I know about tools. I know about batteries. I do appreciate the explainations, though. I am trying to see if anybody here has actually used any of these these cordless routers, and their thoughts on their performance. I like the Makita from what I saw. I just doubt I’ll be inspired to invest in a new battery system for one tool. Especially the higher amp hour batteries I’m sure will be desired for a router. These batteries cost more than the router. And chargers aren’t free. Round overs are a light load, though. I’m an employed professional, and the use would be frequent. But, I’m not a tool addict and don’t want to buy every tool in existence. I’m just looking for reviews from people other than randoms on Amazon. Everybody has given good advice, though. So, thank you.
Things You Need To Know About Woodworking Routers learnexperience General Routing 11 10-16-2011 04:55 PM
