Pattern router bits - Router Forums
 11Likes
  • 1 Post By CarlSparky
  • 2 Post By Stick486
  • 2 Post By Cherryville Chuck
  • 4 Post By MT Stringer
  • 2 Post By Roy Drake
post #1 of 8 (permalink) Old 01-19-2018, 04:27 PM Thread Starter
Default Pattern router bits
I just bought my first plunge router. I am trying to install a Kregg clamp plate in my work bench. I only need to do about 1/4" deep into the table top. The pattern bit I bought at Lowe's has a 1" cutter. The bearing does not touch the pattern when I use a 3/4" pattern. I made a pattern out of 2 x4's and its too high. I don't have a planer. My question is, "Do pattern bits come in varying lengths for the cutter?" I hope this doesn't sound stupid but This is all brand new to me. This is my first post on any forum. Bail me out please!
Roy Drake likes this.
CarlSparky is offline
post #2 of 8 (permalink) Old 01-19-2018, 04:37 PM
use a top bearing mortising bit or use guide bushing......
https://woodworker.com/top-bearing-h...ssu-16-560.asp
Name:	GUIDE BUSHING - TEMPLATE.jpg
Name:	GUIDE BUSHINGS.jpg
Roy Drake and coyote7 like this.
post #3 of 8 (permalink) Old 01-19-2018, 06:31 PM
The short answer is yes: Freud Tools - Search Results for top bearing flush trim
post #4 of 8 (permalink) Old 01-19-2018, 07:05 PM
MT Stringer's Avatar
rip the 2x4 to a usable thickness with your table saw.
Edit: I just measured mine. 1 1/2 should work perfect. That would allow the bearing to ride against the side of the 2x4 and as you lower it, it will begin to cut your pattern.
Edit2: Check out the picture. That is 2ea. 3/4 inch pieces of plywood, so almost 1 1/2 inches thick. The bearing will ride against your 2x4 piece. Shouldn't be a problem. Make a couple of passes either 1/16 or 1/8th inch per pass.
Name:	2018-01-19 19.12.42.jpg
MT Stringer is online now
post #5 of 8 (permalink) Old 01-20-2018, 08:19 AM
First Name: Roy
CarlSparky: Our mantra is: "The only stupid question is the one(s) not asked!" This is a learning site. Glad you used it. You've helped many more than just yourself. Keep in participating.
thomas1389 and hawkeye10 like this.
Roy Drake is offline
post #6 of 8 (permalink) Old 01-20-2018, 08:47 AM
hawkeye10's Avatar
First Name: Don
If your router bits shank is 1/4" be sure and take only a 1/16" cut per pass. The 1/4" shank bits are easier to break.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 8 (permalink) Old 01-22-2018, 06:29 PM
First Name: Roger
If you are taking deep passes with a 1/4" shank bit you better be wearing a bullet proof vest and a thick face shield.!!!!!
Rogerv is offline
post #8 of 8 (permalink) Old 01-22-2018, 09:44 PM
Pretty much the minimum diameter for any pattern bit is 1/2" and it necessarily comes in 1/4" shaft. To get a 1/2" shaft you have to go to a minimum 3/4" diameter and I read recently on Whiteside's website that you should expect reduced service life from the bearing due to it's size/fragility.They recommended to go up to 1" if possible to improve bearing service life.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Bits for Router Lathe daveywoodturner Router Bits - Types and Usage 1 07-03-2017 06:22 AM
Centurion tools router bits kp91 Tool Reviews 6 07-25-2016 09:35 AM
Minimum RPM for Router Bits joprinz CNC Routing 4 12-19-2010 03:52 PM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
