My projects always have "branches" - Router Forums
 16Likes
post #1 of 11 (permalink) Old 01-22-2018, 06:58 PM Thread Starter
First Name: Ken
Default My projects always have "branches"
Simple enough project, a glue gun holder for my wife's sister.
The first branch...this thing is so much nicer than the one I made my wife that I decided there should be two of them.
The
Second branch... a trip to the store (20 miles one way) for a glass tumbler because I decided that would look a lot nicer than the wooden box that was originally going to hold the glue sticks.
The third branch... decided to make a template so they'd both have two recesses in the same place, and so that if someone else wants one I can make it quickly. This would be my first time making my own template. I could NOT get the pattern in the center of a board to save my soul and wasted two attempts. I finally got it today, but the circular recess came out too small by a hair. I put the tumbler through that pattern and drew around the rim to make the circle bigger. I figured I'd use the oscillating sander and sand out to the line, it being only an eight of an inch or so. Very quickly that led to
The fourth branch. Oscillating sanders make some serious dust so I decided I'd just take a few minutes and run a branch dc line from the CSMS, which was just a few feet away. THe "few minutes" ended up being over an hour because I completely redid the line to the CSMS and added the one to the sander, It does look a LOT better than the single line to the saw did, and doesn't block the cabinet door at all, where the original line did keep me from opening one door all the way.
There were other "twigs" along the way, as there always is, but the two bases are now routed and sanded.
I've learned a lot so far...
Still stuff to do, but here's the routed base. Those recesses are flat on the bottom though it's hard to see that. The round one is about a half inch deep, the rectangle is about a quarter inch.
Danman1957, TenGees and bryansong like this.
kklowell is offline
post #2 of 11 (permalink) Old 01-22-2018, 08:13 PM
DonkeyHody's Avatar
First Name: Andy
You told the story of my life. I love the idea of constant improvements, but I'm always improving my nest instead of actually building anything in it. It only got worse after I retired because I'm not under any time constraints.
But it was even more maddening when I was a kid. My dad kept the oil changed in vehicles, but never did any other maintenance until something broke. And he never put anything away, so when the tire that he'd been airing up every morning for a week wouldn't hold air anymore, it was time to find the spare, which was also flat, and the jack, which was probably holding up the corner of the barn. Those experiences had a profound effect on me, because like you, I'll stop in the middle of a project to fix something that bugs me.
Herb Stoops and bryansong like this.
We should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore. - Mark Twain
DonkeyHody is offline
post #3 of 11 (permalink) Old 01-22-2018, 08:18 PM Thread Starter
First Name: Ken
Well, there's that, but there's also that I'm, as my wife says, likely to start 7 different projects and have trouble finishing any.
kklowell is offline
post #4 of 11 (permalink) Old 01-23-2018, 06:49 AM
difalkner's Avatar
First Name: David
My friends laugh at me saying I never finish any projects. But they also know I start 5 times as many as they do and finish at least 4 out of 5, so I figure I'm doing way more than them and the know that too. One day, though, I'd like to go back and finish those stragglers that never quite made it to completion...
David
Gaffboat and Danman1957 like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #5 of 11 (permalink) Old 01-23-2018, 06:54 AM
vchiarelli's Avatar
First Name: Vince
Branches???? I just see squirrels
Danman1957 likes this.
vchiarelli is offline
post #6 of 11 (permalink) Old 01-23-2018, 07:27 AM Thread Starter
First Name: Ken
THat's probably a more honest and accurate way to put it.
vchiarelli likes this.
kklowell is offline
post #7 of 11 (permalink) Old 01-23-2018, 08:19 AM
hawkeye10's Avatar
First Name: Don
I finish all my projects, it's just a matter of when. I am still working on a Christmas present for my daughter.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 11 (permalink) Old 01-23-2018, 09:46 AM
TenGees's Avatar
First Name: Paul
No rush, Don, you still have eleven months to finish it.
TenGees is offline
post #9 of 11 (permalink) Old 01-23-2018, 09:53 AM
TenGees's Avatar
First Name: Paul
Ken, I know what you're talking about. Sometimes I start at the roots though... Still not organized after moving, I go looking for some hardware or something but stumble upon something totally unrelated which can get me going in a whole new direction.
TenGees is offline
post #10 of 11 (permalink) Old 01-23-2018, 10:20 AM Thread Starter
First Name: Ken
Yep, that too. I moved here two years ago and started putting my shop together in the spring. As I needed something and/or found it I would put it somewhere...and then not find it again for a while. I got some old kitchen cabinets and put them in...some solid core doors cut to make countertop/workbenches and I had a shop where I could put stuff in its place and find it again. Yeah, not so much...everything ended up on the countertop or on one of the two or three folding tables.
A month or so ago I decided that my shop would become more organized and safer. Now, a really organized person could have finished it all in a week I think, but I'm still going in starts and stops. While working on a project the short folding ladder kept getting moved, so I stopped and made a place for it to hang. The drill press (little table top model) kept getting pushed side to side...so I stopped and made it a real home. I needed to hold the template I was working on, so I stopped and made a vice. The sanding job I was doing yesterday made too much floating dust, so I stopped and redid my dc piping. THat sort of thing is the branches I refer to, or the squirrels.
Someday maybe if I can get myself more disciplined (my wife almost gave herself an asthma attack just thinking about that one, she laughed so hard) my shop will be at a point where there are fewer branches. I can hope, right?
vchiarelli and TenGees like this.
kklowell is offline
Planning projects for wood movement Duane Bledsoe Tools and Woodworking 27 10-13-2015 09:39 PM
Choosing the best wood for outdoor projects Hamlin Wood Species 5 07-21-2009 07:40 PM
