Craftsman 315.17461 Shaft Lock Repair - Router Forums
 7Likes
post #1 of 11 (permalink) Old 01-27-2018, 01:23 PM Thread Starter
Default Craftsman 315.17461 Shaft Lock Repair
Hello-
I'm new here and I inherited a Craftsman 315.17461 from my grandfather but the shaft lock is broken. The switch slides back and forth but does not lock the shaft in any position. I found the manual on this forum and have looked at threads for similar routers. The manual simply says that it should be taken to a licensed repairman if anything is wrong under the cap. That ain't happenin'.
To start, I can not get the cap off the top. I removed the 3 screws on top and see from other posts that there is a small screw that attaches the red plastic part of the switch to the internal part that I need to remove to get the cap off but I can not see the screw from the outside and don't know how to get access to it. Once the cap is off, does anyone have any advice for how to repair the shaft lock? Thanks
Tim
Tim Fries is offline
post #2 of 11 (permalink) Old 01-27-2018, 01:36 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router forum Tim
Some times craftman hid the screw under a label like the caution label or the horse power label
Thank You John
Semipro is offline
post #3 of 11 (permalink) Old 01-27-2018, 02:05 PM
Tim; with due respect to your Grandfather, and an obvious emotional attachment to his tools, buy a new router. Seriously.
An old Craftsman has no real value anymore, especially now that Sears is rolling up the carpet. I'd bet a 6 pack that most of the older member's here (probably most of us ) started out with a Craftsman router. I did, and I still have it and it still works, BUT it's not my favorite and it certainly isn't the one I reach for.
DaninVan is offline
post #4 of 11 (permalink) Old 01-27-2018, 04:12 PM
I had one of those once and took it apart and it required I get the shaft lock slide out first but I just don't exactly remember how I did it.
post #5 of 11 (permalink) Old 01-27-2018, 08:48 PM
vchiarelli's Avatar
First Name: Vince
Tim - if I remember, seems to me, on my old Craftsman router, I had to push the slide switch in while sliding it sideways for the lock to work. I'm not at home so I can't confirm. Have you tried that?
TenGees likes this.
vchiarelli is offline
post #6 of 11 (permalink) Old 01-28-2018, 04:46 PM
TenGees's Avatar
First Name: Paul
I have a different old Craftsman and as Vince mentioned: I have to push the lever towards the motor and in at the same time, then it works fine. Maybe yours is similar.
TenGees is offline
post #7 of 11 (permalink) Old 01-28-2018, 05:54 PM
Bradford Hooper's Avatar
First Name: Brad
I have one also and I have to push the slide in to lock the rotor
TenGees likes this.
Bradford Hooper is offline
post #8 of 11 (permalink) Old 01-29-2018, 10:21 PM Thread Starter
Thanks everyone for the advice. I managed to figure it out by prying gently on the switch with a screw driver I got the switch to pop up and could see the screw. Miraculously, this also engaged the shaft lock and I can now switch it on and off without a problem. Danin Van, at some point I will get a new router but I honestly don't use it frequently enough to justify it at this point. Thanks again!
Tim
post #9 of 11 (permalink) Old 01-29-2018, 10:56 PM
It has a built in lock out too that won't allow it to be energized while the lock is engaged. Don't ask how I know that.
post #10 of 11 (permalink) Old 02-05-2018, 09:32 AM
First Name: Brad
Tim
Justify.... lol I wouldnt have any toys if I had to justify them lol
BrianS and DaninVan like this.
Craftsman Router Shaft Lock ShawnD General Routing 5 01-02-2014 05:57 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Newbie: Need help changing bit on older Craftsman Router coolguy982 Router Bits - Types and Usage 11 02-28-2010 03:21 AM
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 10:29 AM
Craftsman router shaft galled up! rhodeguy General Routing 7 01-08-2008 06:45 PM
