Collet questions - Router Forums
 8Likes
post #1 of 12 (permalink) Old 02-02-2018, 12:54 PM Thread Starter
Default Collet questions
I have seen posts where people are using adapters so that different sizes of cutter are able to be used. Is it possible to get collet adapters that would allow me to use some of my machinist cutters? Sizes that I'm interested in using are 3/16,5/16&3/8
Jim
Jimjjr is offline
post #2 of 12 (permalink) Old 02-02-2018, 02:27 PM
Country: France
First Name: Gérard
Hello jim !
Welcome here.
You will get some answers soon, but it would be easier if you tell us a bit more
about the router you are using.
router collets are specific to a machine.
Adapters are not specific, but not so accurate.
Machinist system is more flexible , accurate , and expensive , they are in use with cnc 's .(and mechanics).
Regards.
gérard
ggom is offline
post #3 of 12 (permalink) Old 02-02-2018, 03:06 PM
TWheels's Avatar
Collet adapters are widely available. For example, Bushing Adapters - Lee Valley Tools,
https://www.mlcswoodworking.com/shop...ollet+adapters and, by far the widest range of sizes available that I know of is https://www.toolstoday.com/high-prec...306C9A710963F4 are three sources.
I have no doubt @harrysin will see this thread and advocate for the MuscleChuck system, but they do not include the 3/16 and 5/16 adapters http://www.musclechuck.com/shop/
Jimjjr likes this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #4 of 12 (permalink) Old 02-02-2018, 03:28 PM
kp91's Avatar
First Name: Doug
Jim,
While adapters exist, I am a believer in "just because it fits, it doesn't necessarily mean you should use it". Make sure whatever you plan on spinning with a router is rated for the speed. 12,00-24,000 rpm is a lot faster than your average milling machine. I am not sure how a cutter engineered to spin at 5000 rpm would work at that speed.
harrysin, JFPNCM, MEBCWD and 2 others like this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 12 (permalink) Old 02-02-2018, 03:44 PM Thread Starter
Thanks guys
I have used different kinds of collet system on CNC equipment. As a general rule the are pricey to say the least.
I would like to see what's available and cost. Probably be cheaper to buy good cutters and get resharpened when dull.
And YES the rpm may be a problem and if I try it I will probably use remote to turn on from a distance Hahahaha
This kind of conversation is exactly what I need to hear thanks again
Jimjjr is offline
post #6 of 12 (permalink) Old 02-02-2018, 03:48 PM Thread Starter
The router I'm using is M12VC hitachi one on a router table and one plunge
Jim
Jimjjr is offline
post #7 of 12 (permalink) Old 02-02-2018, 04:34 PM
Semipro's Avatar
First Name: John_*
Jim
Here a company that carries a lot of collets
http://m.elairecorp.com/site/index.html?imz_st
Semipro is offline
post #8 of 12 (permalink) Old 02-02-2018, 07:35 PM
I've heard of guys using milling cutters but I don't know how well they worked. And they may have used speed controls to slow the router down to use them at that. Also bits made for cutting metal may not have optimal cutting geometry for wood. Wood cutting bits may have a steeper cutting angle than metal cutting bits to shear wood as opposed to more of a scraping action. All of my mill cutters are also HSS instead of carbide and HSS doesn't wear as well.
post #9 of 12 (permalink) Old 02-03-2018, 06:41 AM Thread Starter
Thank you I'll check it out
Jim
Jimjjr is offline
post #10 of 12 (permalink) Old 02-03-2018, 06:50 AM Thread Starter
Charles,Very good point about geometry. I would expect that the cutter would not perform well in wood. I was thinking since I had them they might work for figuring out processes however the right tool for the job is always a better choice.
Jim
TenGees likes this.
Jim
Jimjjr is offline
bits and collet issues captflx Router Bits - Types and Usage 11 04-28-2017 08:21 PM
Craftsman 1/2" collet jimmiler General Routing 3 01-06-2017 10:21 PM
cnc router collet questions judyhawkins New Member Introductions 3 05-16-2013 12:25 AM
MY PC 7518 collet was junk, I replaced it with a Precision Collet what a difference. Bill Huber General Routing 0 09-25-2012 11:52 PM
Jacob's Power Collet Questions cdevlync General Routing 5 10-20-2010 11:07 PM
