Iron on Edge Banding? - Router Forums
 30Likes
post #1 of 27 (permalink) Old 02-07-2018, 05:48 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Default Iron on Edge Banding?
Has anyone tried Iron -On edge banding for plywood? I can't stand to have the edges of plywood show, so I've always cut strips of solid wood, glued them to the edges, and trimmed flush with laminate trimmer. I always knew there was iron-on banding available, but never really considered it. Now I see where I can get a 250 foot roll of red oak banding for $25. I'll spend several times that, plus a lot of time making 250 linear feet of banding. The task at hand is just a chest of drawers for shop tools, so it's a good place to experiment. My question is, does it stay on reliably??
DonkeyHody is offline
post #2 of 27 (permalink) Old 02-07-2018, 05:55 PM
Yes. Absolutely, Andy; love it. I never use MDF so it's either solid edging or iron on; not a lot of other options...vinyl moulding is a bit 60's.
Either buy your own iron or be reeaaaaly careful that you check your wife's iron for residue when you're finished...she will not be impressed with glue on her $200 blouse. *lips are sealed!*
Danman1957, TenGees, Nickp and 4 others like this.
DaninVan is offline
post #3 of 27 (permalink) Old 02-07-2018, 06:19 PM
yes, for decades...
just use an ordinary clothes iron set to DRY high heat...
a roller is a good bet when applying.....
if you get blisters/ripples no matter how careful you are... it is often the banding.. the cheap imported stuff does that...
Edgebanding Guide - A Simple Method Yields Superb Results
Danman1957, Roy Drake and jj777746 like this.
post #4 of 27 (permalink) Old 02-07-2018, 07:40 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Just what I wanted to know! Thanks Y'all!
post #5 of 27 (permalink) Old 02-07-2018, 07:43 PM
MT Stringer's Avatar
Yes. And I use a setup similar to what Stick posted. Clamp up several pieces, iron on the banding and then trim. Works well.
MT Stringer is online now
post #6 of 27 (permalink) Old 02-07-2018, 07:51 PM
I picked up an old iron at a garage sale and have it in the shop dedicated to edge banding.
DaninVan, Danman1957 and Roy Drake like this.
Herb Stoops is offline
post #7 of 27 (permalink) Old 02-07-2018, 07:52 PM
Yes, would work for edge banding plywood carcasses, drawer fronts too, although I lean towards solid edging if it's going to see heavy/rough service. I've done enough of it that I bought one of the purpose made irons although, as mentioned, your wife's iron will work - just be sure to clean it thoroughly before returning. I never had much luck with rolling the banding, preferred to rub it with a softwood block with rounded edges as I felt I got a more even force - and I used the block to rub out laminate edging too.
There was a similar thread recently, talking more about trimming the edges - knife, razor blade, chisel, etc. - but I've always used the edge of a file the way I was taught by a gentleman who worked for a company that made institutional cabinets all his life. If you keep the file at a shallow angle and feed sideways as you stroke, the overhang can come off in a continuous curl, very quick once you get the hang of it.
If you think a heavier edging is preferable, I just read about a company on another forum that sell both the regular wood tape as well as heavier 1 mm, 2 mm and 3 mm thick product. I've never dealt with them and think you have to contact them for prices.
https://edgecoinc.com/veneer-wood-edge-banding-thick/
Gaffboat and TenGees like this.
tomp913 is online now
post #8 of 27 (permalink) Old 02-07-2018, 08:31 PM
CharleyL's Avatar
First Name: Charley
I did the same, but found my iron in a re-store for $2, It works great for this, but doesn't get used much.
I prefer making solid wood strips and gluing them on. For a couple of recent cabinets using 3/4 birch cabinet ply that needed stain and poly finish, I made 3/4 X 3/4 soft maple strips and joined the cabinet sides at the cabinet corner into it using biscuits and glue. When trimmed and sanded, the soft maple grain and color was very close to the surface veneer of the cabinet birch. The soft maple has since been my preferred solid wood for covering cabinet birch end grain, even when as thin as 1/8" (without biscuits).
Charley
Herb Stoops likes this.
Central North Carolina
CharleyL is online now
post #9 of 27 (permalink) Old 02-07-2018, 09:20 PM
I suggest that you put a coat of glue on the edges first. Then iron the strips on.
post #10 of 27 (permalink) Old 02-07-2018, 09:57 PM
It's OK for quick and dirty, but I by far prefer cutting strips, gluing them up , trimming smooth. The iron on doesn't improve the strength of a shelf, a good hardwood strip does. Glue thoroughly, I put 2 coats on the ply edge because it really soaks in. Clamp the strips in place same as you would glue up a panel. If I'm going for strength, the strip will be about 3/4 inch wide.
With iron on strips, you still have to trim the strips even with the ply. If the strips are solidly attached, then trimming can be done with a sharp block plane, or you can purchase a trimmer. I personally only have disasters trying to use a chisel or another blade. You can use a trim router as well. And as mentioned, I prefer to use a slightly rounded stick rather than a roller. Never tried applying glue first...I'd want to test that out on scrap first.
Man, you sure got that question answered thoroughly.
Oh yes, welcome to the Forum.
DesertRatTom is online now
Trimming wood edge banding Cherryville Chuck Table-mounted Routing 4 10-29-2016 07:09 PM
Problem with Trimming Edge Banding chuckgray Tools and Woodworking 19 09-20-2016 07:32 AM
Edge Banding Router Bit Sets patlaw General Routing 15 02-02-2016 01:10 PM
Flush Trimming Edge Banding JIMMIEM General Routing 6 01-08-2015 06:35 AM
edge banding spidennis Router Bits - Types and Usage 10 05-07-2013 09:24 AM
