alternative to Kreg screws - Router Forums
 14Likes
post #1 of 27 (permalink) Old 02-07-2018, 07:01 PM Thread Starter
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Thumbs down alternative to Kreg screws
Has anyone found a viable alternative to Kreg pocket hole screws??
Lowes has washer head screws but with limited length selection
looking in particular for 1" length, coarse, for attaching "3/4" ply interior use
1 1/ 4" length pokes through the attached wood so I need the shorter length
AND
I would like to source an alternative to the whole premise of Kreg's monopoly. Square drive preferably.
I can get the smaller head screws but not the washer heads
thks
smitty
smitty10101 is offline
post #2 of 27 (permalink) Old 02-07-2018, 07:15 PM
First Name: Quenten
I saw some on Grizzly's site in their close out section. Lots of pages, gotta just go through them to see if they have the size your after.
Tonto1 is offline
post #3 of 27 (permalink) Old 02-07-2018, 07:18 PM
DonkeyHody's Avatar
First Name: Andy
I buy Kreg screws by the 500 count box from Amazon. Much cheaper that way.
https://www.amazon.com/Kreg-SML-C1-5...70_&dpSrc=srch
That gets you down to 3.4 cents per screw. I don't expect you'll do a lot better than that.
hawkeye10 likes this.
We should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore. - Mark Twain
DonkeyHody is offline
post #4 of 27 (permalink) Old 02-07-2018, 07:26 PM
Here's one option, a little pricey
https://www.clipsandfasteners.com/6_...k_p/a12952.htm
Another, a little better price
https://www.wwhardware.com/low-profi...ad-screw-sclp8
Quick Screws has a better selection, pick your point style and finish
https://www.quickscrews.com/catalog/...5D=Washer+Head
I've dealt with both Quick Screws and Woodworkers Hardware, good service from both.
tomp913 is online now
post #5 of 27 (permalink) Old 02-07-2018, 07:39 PM
MT Stringer's Avatar
Smitty, I think you are drilling your pocket too deep. Adjust the collar on your drill bit so it drills a pocket that is a little more shallow. Test it out. Hope this helps.
MT Stringer is online now
post #6 of 27 (permalink) Old 02-07-2018, 07:58 PM Thread Starter
First Name: smitty
Mike-- had it set for 3/4 and the tip just broke through
reset it for 5/8 & it was fine
measured the ply &---it miked out @ .705
looking at the screws after the reset to 5/8 it appeared that the length into the receiving wood was going to be acceptable
of course IF the manufactures actually gave us 3/4 or 1/2 or whatever dimension that we bought then I wouldn't have this problem
Yeah--right
post #7 of 27 (permalink) Old 02-07-2018, 07:59 PM Thread Starter
First Name: smitty
@ tomp913
thks for the alternative sources
will check them out
smitty
post #8 of 27 (permalink) Old 02-07-2018, 08:00 PM Thread Starter
First Name: smitty
@ everyone that replied
thks for the responses
smitty
post #9 of 27 (permalink) Old 02-07-2018, 08:03 PM
First Name: Earl
Yep--the "3/4" ply is more likely 11/16" so if the jig is set dead on 3/4" the hole is deeper than expected, and the material you're going into is thinner. I pull the tip of the bit back a little when i'm using ply (if I mill solid lumber, it's 3/4" exactly so not a problem). I've done it enough that i have an eyeball on where i need to be with collar--but at first it was a little trial & error. I think at some point i had a pencil mark on the collar setting thing--but it's worn off now.
Kreg's screws are good quality in my eye, but i buy most of mine on Amazon Warehouse. Usually the boxes are just beat up. I may be short a few screws, but when you find them on the warehouse i usually get them at 25% to 30% below street price.
McMaster-Carr may have a good alternative, but i'd want to see the self tapping set-up compared to what Kreg uses before buying any real quantity. That Kreg design does a great job of helping to draw the pieces together.
Good luck!!
earl
EDIT--i must type slow...the whole thing was solved between the time i started & finished!!
DaninVan and Web Shepherd like this.
greenacres2 is offline
post #10 of 27 (permalink) Old 02-07-2018, 08:16 PM
CharleyL's Avatar
First Name: Charley
I had a recent need to use Kreg's mini pocket hole jig and I needed stainless screws. Of course, Kreg only make stainless screws in one size and length, and they are for the standard Kreg jig. I ended up using Phillips rround head stainless screws of the length that I needed and it worked fine. The smaller Kreg drill made a hole almost the prefect size for the stainless screws that Lowes had. I believe they were #7 (from memory).
I know I didn't answer your question, but sometimes you can find standard screw hardware that will work fine with the Kreg jigs and one of them might be the solution. You need the right head diameter and a flat bottom on the head. Satisfy this and most any screw will work. Don't use flat head screws because the bottom side of their heads is cone shaped and will split the wood with the pocket hole.
Charley
jj777746 and hawkeye10 like this.
Central North Carolina
CharleyL is online now
Kreg ≠ Incra...specifically the Kreg Swing Stop! niswanger Table-mounted Routing 19 01-28-2020 10:59 PM
Kreg rip-cut saw guide - alternative JOAT Tools and Woodworking 13 02-04-2018 06:11 PM
Kreg pocket hole screws RainMan 2.0 Jigs and Fixtures 25 03-14-2017 02:07 AM
Kreg pocket hole screws. hawkeye10 Tools and Woodworking 16 09-24-2015 09:05 AM
Kreg screws more than 50% off volunteers The Bargain Bin 3 05-28-2011 06:11 PM
