Triton Router trouble - Router Forums
 16Likes
  • 5 Post By JOAT
  • 4 Post By hawkeye10
  • 1 Post By Cherryville Chuck
  • 1 Post By whimsofchaz
  • 5 Post By DonkeyHody
post #1 of 10 (permalink) Old 02-07-2018, 08:43 PM Thread Starter
Default Triton Router trouble
Greetings All,
I purchased a 3hp Triton TRA001 years ago and finally got it out of the box. Was installing in my router table, put bit it, fence on and was tucking cord in place. I inadvertently hit power button under table and bit slammed into my custom(wood) fence. Machine instantly shut off but wont restart. Switch has power, but nothing. There an internal reset on these things somewhere? I took thing apart and bypassed switch but still no go. Anyone give me a pointer on where to start?
SquidUSA is offline
post #2 of 10 (permalink) Old 02-07-2018, 09:45 PM
I'd check your instruction book or better, contact Triton customer service on the website. I know they have released a number of improved versions of that router. Sounds like there ought to be a reset, either on the machine or in the circuit feeding it. For example, some multi outlet extension boxes have a reset, or it may be on a circuit with GFCI outlet. Most resets are tiny and pretty hard to find, particularly if your vision is aged.
DesertRatTom is online now
post #3 of 10 (permalink) Old 02-07-2018, 11:45 PM
JOAT's Avatar
First Name: Theo
My vision is now 20/20 since my eye cataract surgery. But it is amazing how helpful a magnifying glass carried in a pocket can be. Bonuses, you can start a fire with one, and fry ants.
I also carry a small flashlight. Very useful also.
JOAT is online now
post #4 of 10 (permalink) Old 02-08-2018, 11:07 AM
MT Stringer's Avatar
Originally Posted by SquidUSA View Post
Greetings All,
I purchased a 3hp Triton TRA001 years ago and finally got it out of the box. Was installing in my router table, put bit it, fence on and was tucking cord in place. I inadvertently hit power button under table and bit slammed into my custom(wood) fence. Machine instantly shut off but won’t restart. Switch has power, but nothing. There an internal reset on these things somewhere? I took thing apart and bypassed switch but still no go. Anyone give me a pointer on where to start?
Welcome aboard.
Mine has a plastic cover over the switch that has to be pushed out of the way in order to allow access to the Start button. Did you check that?
EDIT: Never mind, I didn't read close enough. You already have the switch apart. Sorry about that.
MT Stringer is online now
post #5 of 10 (permalink) Old 02-08-2018, 11:48 AM
I also keep a tiny flashlight on my car key chain. Reading menus in dark restaurants is impossible without it. Hadn't thought of adding a magnifier. I contacted Triton via email this a.m. about your question and will post when and if they reply. If you can locate the serial number, I think that will help them respond.
post #6 of 10 (permalink) Old 02-08-2018, 12:24 PM
hawkeye10's Avatar
First Name: Don
Greetings All,
I know hindsight is 20-20 but I guess the number one safety rule is unplug any power tool when working on it.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 10 (permalink) Old 02-08-2018, 04:06 PM
Welcome squid. The only other simple thing I can think of is maybe it knocked one or both brushes out of place. Along the lines of what Don said, you also want to get in the habit of unplugging the router when you change bits. Accidentally starting the router while you are holding the bit or have a wrench on the collet can be a serious safety issue. You've already found out how easy it is to start it by accident.
ggom likes this.
post #8 of 10 (permalink) Old 02-08-2018, 08:56 PM
whimsofchaz's Avatar
First Name: Chuck
[QUOTE=JOAT;1808057]My vision is now 20/20 since my eye cataract surgery. But it is amazing how helpful a magnifying glass carried in a pocket can be. Bonuses, you can start a fire with one, and fry ants.
Saw this and bought a mag glass with LED immediately...How long does it take to use a good idea?
jj777746 likes this.
whimsofchaz is offline
post #9 of 10 (permalink) Old 02-08-2018, 10:22 PM
DonkeyHody's Avatar
First Name: Andy
I don't unplug my router. And I didn't like fumbling around under the table to find a switch. So I added an external switch that's easy to reach, yet difficult to flip accidentally. The plastic dome was intended for use as a weather cover to protect a receptacle while a cord is plugged into it. I repurposed it by making an oval hole in the dome so I can insert a finger to flip the switch.
We should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore. - Mark Twain
DonkeyHody is offline
post #10 of 10 (permalink) Old 02-09-2018, 07:05 AM
Nickp's Avatar
First Name: Nick
Is it possible the shaft is raised all the way up, interlock on and shaft is locked...?
Put it all back to normal...switch interlock is there for safety reason...
Nick
Nickp is offline
Coping Sled Suitable For Triton RTA 300 Router Table Gaia Jigs and Fixtures 11 11-25-2015 02:15 PM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Triton Router aeb430 Table-mounted Routing 18 12-23-2013 05:00 PM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
Triton Router & Router Raizer kenrg Table-mounted Routing 18 11-24-2009 12:53 PM
