Sticky Adjustment - Router Forums
 2Likes
  • 1 Post By Stick486
  • 1 Post By vchiarelli
post #1 of 10 (permalink) Old 02-12-2018, 11:42 AM Thread Starter
Question Sticky Adjustment
I have just purchased two Craftsman 315.269210 routers. Both are working and need a good clean up. The only problem I can see at this point is that both have very sticky depth adjustments. How difficult is it to disassemble them enough to solve this problem?
Russo79 is offline
post #2 of 10 (permalink) Old 02-12-2018, 12:25 PM
sticky usually means somebody used petroleum based lube on them such as WD40, oil or grease..
you maybe able to clean them up w/ brake cleaner aerosol and then re-lube w/ a dry lube such as TriFlow...
jj777746 likes this.
post #3 of 10 (permalink) Old 02-12-2018, 01:27 PM
vchiarelli's Avatar
First Name: Vince
Welcome Russo - a quick search of the forums shows that this is a common problem with that router. A suggested solution was to try to get some baby powder between the ring and the motor and attempt to turn the ring back and forth. You could also try using compressed air to attempt to get out any accumulated saw dust that might be in there. And the final suggestion was to just get rid of the router and get a new one.
vchiarelli is offline
post #4 of 10 (permalink) Old 02-12-2018, 01:28 PM Thread Starter
Sounds good. I'll give it a try.
Russo79 is offline
post #5 of 10 (permalink) Old 02-12-2018, 02:38 PM
JOAT's Avatar
First Name: Theo
I guess I'm always going to do things different. I have several Craftsman routers. My solution to that problem was, to make each router a dedicated router for a particular height, so now never need to make any height adjustments, just drop another router in place on its own individual router plate. Works for me.
JOAT is offline
post #6 of 10 (permalink) Old 02-12-2018, 03:43 PM
Is brake cleaner compatible with that type plastic? Some solvents will make the plastic even more sticky. I agree with the dry lube. I had one of those type routers once too. It seems to me that if used regularly that they weren't a problem. Certainly you want the threads to be clean.
post #7 of 10 (permalink) Old 02-12-2018, 04:11 PM
a test clearly in order...
post #8 of 10 (permalink) Old 02-12-2018, 09:53 PM
vchiarelli's Avatar
First Name: Vince
That's great Theo, but the OP has a problem with a sticky height adjustment. Unless he gets that fixed, your solution isn't going to help him.
hawkeye10 likes this.
post #9 of 10 (permalink) Old 02-12-2018, 11:26 PM
JOAT's Avatar
First Name: Theo
OK, try this. I had to spread the collar, and in a couple of cases apply quite a bit of force to get them started. Don't recall that I used any lube, just worked them back and forth until they turned pretty easily. Took awhile. That was years ago, probably all stuck again by now.
JOAT is offline
post #10 of 10 (permalink) Old 02-13-2018, 12:04 AM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
Need help with Milwaukee 5616 depth adjustment jnbrown General Routing 3 11-09-2015 09:00 AM
craftsman depth adjustment mrelmo General Routing 6 09-19-2013 12:58 PM
Newbie question about above table height adjustment patdavid Table-mounted Routing 6 02-13-2013 04:46 AM
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 03:30 PM
