Have you checked the pulleys on you woodworking tools - Router Forums
 3Likes
  • 1 Post By BrianS
  • 2 Post By CharleyL
post #1 of 9 (permalink) Old 02-13-2018, 11:58 AM Thread Starter
First Name: Larry
Default Have you checked the pulleys on you woodworking tools
This is the shaft of a Jet 16'' planner motor bought in March 2014.
The key slipped on the shaft this is the result. Now before you say
I hog out to much at one time NO that is not the case. I take small
bites a half to a quarter turn per pass. I called a motor repair and they
could fix it, but said it would cost same as a new motor. So $500.00
later I have a new motor.
Name:	Key slipped on planner moter shaft..jpg
Knot working is offline
post #2 of 9 (permalink) Old 02-13-2018, 02:05 PM
Semipro's Avatar
First Name: John_*
Just looks like metal fatigue to me, just a bad metal tempering job
Semipro is online now
post #3 of 9 (permalink) Old 02-13-2018, 02:49 PM
difalkner's Avatar
First Name: David
It's a shame the pulley didn't take the hit instead of the shaft - ugh!
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 9 (permalink) Old 02-13-2018, 03:53 PM
BrianS's Avatar
First Name: Brian
Ouch! Looking at the length of the keyway, that was a short key as well... might have been a contributing factor.
Really a moot point now that you have the new motor, but if you know a welder, I don't think that would have been that difficult to repair.
Danman1957 likes this.
Brian
(Origin uncertain)
BrianS is offline
post #5 of 9 (permalink) Old 02-13-2018, 08:39 PM
CharleyL's Avatar
First Name: Charley
For a motor of mine, I would dis-assemble it and take the rotor and shaft to a friens's machine shop, cut a new keyway on the opposite side of the shaft, re-assemble the motor with a new key and pulley, using blue Loctite on the set screw, probably backing up the set screw with a second on on top of the first to lock the first in place, and put the motor back into service. No way would I buy another motor if I could save this one.
Charley
Danman1957 and hawkeye10 like this.
Central North Carolina
CharleyL is online now
post #6 of 9 (permalink) Old 02-13-2018, 10:47 PM
hawkeye10's Avatar
First Name: Don
Charley
Good idea, Charley.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 9 (permalink) Old 02-14-2018, 12:19 AM
JOAT's Avatar
First Name: Theo
Charley
I know there is a way to rescue that, but can't recall just what it is now, but does involve seeing a machinist. Not your way, but your way should work just as well. A machinist might even know a different way to fix the problem. I'm like you, I would definitely take it to a machinist first.
Somewhere along the line I recall someone drilling thru the pulley and shaft, and putting a bolt thru them. As far as I know whatever it was no more problems with it. I think it was the pulley that went somehow. Don't know if I would recommend that or not, I suppose it would depend on circumstances at the time.
JOAT is online now
post #8 of 9 (permalink) Old 02-14-2018, 08:35 AM
CharleyL's Avatar
First Name: Charley
Putting a bolt through the pulley and motor shaft is a good way to destroy both the motor and pulley. There would be no way to tightly join the motor shaft and pulley, and they would tear each other apart in a short time. They repair shafts with bad keyways on very large motors by welding up the damaged area of the shaft and then machining a new keyway, but for a small motor, just cutting a new keyway on the opposite side of the shaft is usually the easiest and cheapest way to save the motor.
Charley
post #9 of 9 (permalink) Old 02-14-2018, 10:47 AM
Danman1957's Avatar
I agree that that was repairable. I worked in sales for a machine shop for 1 1/2 yrs and saw some of the older conventional machinists work miracles. Weld to rebuild surface using appropriate welding materials and procedures, then machine to re balance and finally re-cut a new key way. I would still have it done to have a back up motor. The cost would not be anywhere near the new one.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
New Here Ship4Brains New Member Introductions 26 01-03-2018 05:43 PM
Xmas - I got a Triton TRA001....now what table? mikeyo76 New Member Introductions 10 12-26-2017 04:13 PM
Another Newby Tweety New Member Introductions 13 12-18-2017 06:38 AM
New Guy In Town don Roberto New Member Introductions 15 07-25-2017 03:43 AM
Hello everyone Martin Reed New Member Introductions 11 03-11-2017 08:47 PM
