Slot cutting outside edge of a circle - Router Forums
 4Likes
post #1 of 15 (permalink) Old 02-17-2018, 11:29 AM Thread Starter
Renelle Musielak-Legos's Avatar
First Name: Nell
Question Slot cutting outside edge of a circle
I'm very new to routing, so if there's an easier way to do this, even without a router, please let me know.
I want to cut a slot into the edge of a few different sized circles, one size being 6" in diameter and the others smaller.
What would be the best way to do this? I don't have a router table but if one would make it easier, I'll build one.
I'm trying to make the edge of a bobbin that will be used on a large spinning wheel (for wool, not a random wheel that spins).
Renelle Musielak-Legos is offline
post #2 of 15 (permalink) Old 02-17-2018, 11:40 AM
coupl3e of ways..
use your existing router guide...
a circle router base....
http://jaspertools.com/
make what works best for you...
https://duckduckgo.com/?q=router+cir...deos&ia=videos
post #3 of 15 (permalink) Old 02-17-2018, 11:52 AM Thread Starter
First Name: Nell
Maybe I didn't explain myself well enough. I already have the circles cut out. Now I need to make a slot all the way around the outside edge so it acts like a gear, without the teeth. Like the ones pictured but with one slot, not multiple. Unless I'm missing something and the things you linked would work for that too?
It has been my experience that folks who have no vices have very few virtues. -Lincoln
post #4 of 15 (permalink) Old 02-17-2018, 12:01 PM
hawkeye10's Avatar
First Name: Don
I am not kidding, my first router table was a piece of plywood on top of a 55-gallon drum. I bored a hole in the ply and mounted the router underneath. Yes, it was crude but it got the job done until I could do better.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 15 (permalink) Old 02-17-2018, 12:17 PM
Rebelwork Woodworking's Avatar
First Name: Jack
For a pulley correct? Similar to this
http://www.jackdurencabinets.com/homepage.htm
Rebelwork Woodworking is offline
post #6 of 15 (permalink) Old 02-17-2018, 12:27 PM
you don't want a slot.. you want an edge treatment, a profile...
and yes those things I pictured will work...
IRL, all you need is a bearing guided bit...
double stick tape to a good work surface and and profile away..
EDIT..
now that I see your second post...
this bit..
https://www.toolstoday.com/edge-flut...uter-bits.html
post #7 of 15 (permalink) Old 02-17-2018, 12:27 PM Thread Starter
First Name: Nell
Yes! I figured a small slot would work just as well as that bit (but that bit is the ideal). I'm just not sure of how I'd make it around the circle in the best fashion.
post #8 of 15 (permalink) Old 02-17-2018, 12:37 PM Thread Starter
First Name: Nell
Awesome. Thank you so much! I'll buy one of those then, if it'll make that much of a difference. Do you know the specific name for that bit?
post #9 of 15 (permalink) Old 02-17-2018, 12:38 PM
First Name: Jack
Correct?
post #10 of 15 (permalink) Old 02-17-2018, 12:38 PM
RainMan 2.0's Avatar
Neil , I use something simular to what Stick has mentioned. You can cut out a new circle , and make a groove / slot by changing the routers depth if you desire . It does require a 1/8” hole in the centre for a guide pin though . If neccesary, you could . This would work for what your describing, and I’m sure you can fabricate a circle jig easy enough if your budgets tight, and use whatever guide pin diameter you need
Ok ,I never insulate
RainMan 2.0 is offline
Small Circle Cutting (no centre hole) Cowbell General Routing 14 05-26-2014 08:20 AM
slot cutting bit David2058 Router Bits - Types and Usage 28 12-23-2011 06:43 PM
Cutting a Circle rjg202 Tools and Woodworking 15 11-12-2011 08:44 AM
Cutting a slot in the middle of a board Zurt Table-mounted Routing 11 01-11-2011 09:46 AM
Routing outside edge of a circle barryaclarke Table-mounted Routing 1 12-10-2010 08:34 AM
