Shop Vac and RPM - Router Forums
 7Likes
  • 4 Post By difalkner
  • 1 Post By hawkeye10
  • 2 Post By Stick486
post #1 of 9 (permalink) Old 02-19-2018, 03:21 PM Thread Starter
First Name: stuart
Default Shop Vac and RPM
Hi there,
I'm trying to get my new lock miter bits figured out. When I turn on my shop vac, it seems to me like it sounds like the router loses a bit of power. Should I factor that drop in power as a drop in RPM?
many thanks
stuart
Stuart Wallace is offline
post #2 of 9 (permalink) Old 02-19-2018, 03:40 PM
difalkner's Avatar
First Name: David
What's the power draw on each? Do you have extension cords in place? Are the router and shop vac plugged into the same outlet, same circuit?
Yes, in answer to your question. If you're setting it at 18k rpm, for instance, and it slows to 16k rpm then you may need to set it at 20k rpm to compensate. But I would be more interested in figuring out why it's slowing down first.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 9 (permalink) Old 02-19-2018, 04:19 PM
What David said! In spades.
DaninVan is offline
post #4 of 9 (permalink) Old 02-19-2018, 04:57 PM
what David said...
and the drop in voltage generates more heat in both units.. not a good plan...
post #5 of 9 (permalink) Old 02-19-2018, 05:04 PM
Country: France
First Name: Gérard
scientific method:
Use a voltmeter , measure voltage on line when nothing runs,
measure with router on, measure with both on.
If it goes down more than about 10 percent, you got a too long,
or too thin power line.
say 100% voltage is 100 % power on router
then 90 % voltage will give 81 % power at router.
You can see it changes fast.
Approximative explanation:
P (power)= U x U ( U= voltage) So it is U at power of 2 divided by resistor value.
R
It is right for pure resistors like a calorific heater, but It' s an aproximation, because with an universal motor, the power reduction is worse than that.
so if U= 1 (100%) then U to a power of 2 is U x U = 1 x 1 = 1 (100 %)
If U= 0.9 ( 90%) then U to a power of 2 is U x U = 0.9 x 0.9 = 0.81 ( 81%)
That shows how fast a 10 % voltage drop gives a 20 % power loss.
ggom is offline
post #6 of 9 (permalink) Old 02-19-2018, 08:54 PM
One other question. Where is the vac sucking from? Near the bit or out of the bottom of a box?
post #7 of 9 (permalink) Old 02-19-2018, 09:06 PM
hawkeye10's Avatar
First Name: Don
Originally Posted by Stuart Wallace View Post
Hi there,
many thanks
stuart
Stuart, I had a similar problem and added two more circuits. I started blowing breakers. I knew from the start at this house I was going to have to add circuits and kept putting it off until a couple of months ago. You might as well fix your problem now.
DaninVan likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 9 (permalink) Old 02-19-2018, 09:06 PM
Plug them into different outlets, aee if there is any change.
Herb Stoops is offline
post #9 of 9 (permalink) Old 02-19-2018, 10:05 PM
but on different circuts
Danman1957 and Herb Stoops like this.
Many questions for new shop and hopefully the right place to post bclarknc Tools and Woodworking 24 07-13-2016 05:08 PM
new router bit threw sparks, burned my Shop Vac boru New Member Introductions 12 12-14-2013 02:28 PM
Router sled AxlMyk AxlMyks' stuff 18 09-01-2007 06:28 AM
