Low profile riving knife. - Router Forums
 8Likes
post #1 of 14 (permalink) Old 02-20-2018, 09:52 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Low profile riving knife.
I have a Jet Pr Shop 1 3/4hp table saw and I am looking for a low profile thin kerf riving knife. I have called Jet and they don't make one for my saw. They only have full kerf riving knives. Any suggestions?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 14 (permalink) Old 02-20-2018, 10:59 AM
I guess you could have one cut and finished at a machine shop. Use the thin one as a template. Might need to thin part of it down to fit the slot. Personally, I've switched to full kerf blades, they just work better without deflection.
post #3 of 14 (permalink) Old 02-20-2018, 12:24 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Tom, I was using a full kerf also but I was getting a lot of burning while ripping. I then used my ripping blade and the burning was better but not gone. That is when I installed my thin kerf blade it stopped the burning. My saw is a 1 3/4HP and the thin kerf blade cuts easier but I agree a full kerf blade is better.
DesertRatTom likes this.
post #4 of 14 (permalink) Old 02-20-2018, 12:30 PM
Make your own out of an old thin kerf blade or find a piece of metal the same thickness. Use the one you have for a pattern.
Just saying,
Herb Stoops is offline
post #5 of 14 (permalink) Old 02-20-2018, 12:40 PM
Semipro's Avatar
First Name: John_*
Check this out same company that makes the microgripper.
https://www.google.com/shopping/prod...HVF6C6IQ8wIIQQ
JFPNCM and Herb Stoops like this.
Semipro is online now
post #6 of 14 (permalink) Old 02-20-2018, 01:11 PM
Herb has the plan...
post #7 of 14 (permalink) Old 02-21-2018, 07:19 AM
Stoneface's Avatar
First Name: Frank
I do not have a riving knife for my old craftsman table saw. I use the micro gripper. The do keep the saw kerf from pinching the blade but does not prevent burning when cutting Walnut.
Frank
Frank
Stoneface is offline
post #8 of 14 (permalink) Old 02-21-2018, 07:24 AM
First Name: Ken
A riving knife is one of those things I'd like to have, but no one makes one for my old Delta. It originally had a splitter, so it isn't that old, but even that was lost before I got the saw. I thought about a micro splitter, but the blade comes very close to the end of the insert when it's all the way up so I don't think there's room for one.
kklowell is offline
post #9 of 14 (permalink) Old 02-21-2018, 09:17 AM
First Name: rob
The oem insert has another slot for the original splitter, you have lots of room there but more to the point with a thin kerf you will want a zero clearance insert anyway so there is loads of room for a slitter add-on.
tooler2 is offline
post #10 of 14 (permalink) Old 02-21-2018, 09:36 AM
First Name: Ken
I don't see any extra slot in the OEM insert. This saw is a 34-670, which isn't very big, the table is only 22" front to back.
Out of curiousity I just did a Google search to determine how old this saw might be. The oldest reference I saw is a manual from 1995. I really thought this saw was older than that.
kklowell is offline
Bosch 4100 EQUINOX400 Tools and Woodworking 23 09-16-2014 01:39 PM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
Riving Knife Along With Feather Board Jerry Bowen Tools and Woodworking 29 11-28-2012 03:30 PM
Need Info On A Riving Knife Jerry Bowen Tools and Woodworking 31 11-20-2012 04:58 PM
Hybrid table saws-any of them have a riving knife? sig2269mm Tools and Woodworking 1 01-01-2008 09:22 AM
