6"widex1"deep dado - Router Forums
 11Likes
  • 5 Post By DonkeyHody
  • 4 Post By Cherryville Chuck
  • 2 Post By DaninVan
post #1 of 4 (permalink) Old 02-20-2018, 06:02 PM Thread Starter
Default 6"widex1"deep dado
Im trying to form a cap for a fence that I have built with 4x4 posts 2x4 rails and 5/4 deckboard fence posts. The plan was to rip 1" cuts over and over until I have cleared out a one inch deep track 6.25" wide leaving 1 and 5/8" inches on either side of a 2x10. It takes a little over an hour to do one 16 footer and that doesn't include cleaning it up. Does anyone have any thoughts? I have 300' to go.
fenceguy is offline
post #2 of 4 (permalink) Old 02-20-2018, 06:22 PM
DonkeyHody's Avatar
First Name: Andy
I think you're doing it the hard way. Rip some 1 and 5/8" strips and glue/screw them to the bottom side of your 2X10. It'll sit an inch higher, but who cares?
DonkeyHody is offline
post #3 of 4 (permalink) Old 02-20-2018, 10:14 PM
Sounds like Andy has a better idea. Possibly even better is to step Andy's strips back about 1/2" and then 1/4" in from the edges cut a groove with a table saw or circular saw about 1/4" deep. That will prevent water from rolling around the edge and getting into the strips Andy is suggesting, which will help prevent premature rotting. That's what I do when I make window sills.
post #4 of 4 (permalink) Old 02-21-2018, 12:33 AM
What they said. With an air-nailer you'll be done by lunch tomorrow. I second Charles comment about the drip grove.
Mind you, if it's all pressure treated.
Rather than attach them to the 2x10" I just use PT 1x2 and brad nail them to the fence boards, tight up to the underside of the top cap. Just to be clear, I put mine on with the 3/4' edge on top, ie the 1 1/2" dimension is facing outwards.
Make sure you buy hot galv. airnails. 18ga is just fine...16ga if you have them.
harrysin and jj777746 like this.
DaninVan is online now
Miter Dado from Rockler Herb Stoops Tools and Woodworking 18 03-23-2017 08:16 PM
Help designing a repetitive dado jig jevansoh Jigs and Fixtures 32 12-13-2014 10:52 AM
Adjustable Dado Jig for Plunge Router diggerop Jigs and Fixtures 3 11-08-2009 02:47 PM
Adjustable Dado jig - setup problems rovenm Jigs and Fixtures 2 09-21-2009 02:06 PM
Dado cuts in plywood BK9MJE Tools and Woodworking 4 04-18-2009 01:28 PM
