Ryobi Re601 eletronic controller - Router Forums
 3Likes
post #1 of 17 (permalink) Old 02-25-2018, 08:31 PM Thread Starter
First Name: Peter
Default Ryobi Re601 eletronic controller
Hi
I have a Ryobi Re601 which I bought 20 years ago for a specific competition piece. I wish to sell it now but realize there are no parts for this machine which was built in Japan. If its electronic controller went is there another way to keep it working, either with another card from another maker or with an external device? I will not be selling it without this way- out if things go wrong.
Thanking you in anticipation
regards
Peteroo
Peteroo1 is offline
post #2 of 17 (permalink) Old 02-25-2018, 08:42 PM
by pass the controller and add an external controller..
point.. the external controller will probably be worth more than the router...
Mycrossover likes this.
Stick486 is offline
post #3 of 17 (permalink) Old 04-19-2018, 09:33 AM
The cheap one from Harbor Freight is 20 bucks less the ever present 20% off coupon. A lot of happy custoners. A good one can be had for around 30 or 40 bucks. The heavy duty one, not the cheaper one from MLCS is very good.(free shipping on anything).
Sent from my SM-G900V using Tapatalk
Mycrossover is offline
post #4 of 17 (permalink) Old 04-19-2018, 09:42 AM
none of them can hold their own against a Bosch...
Stick486 is offline
post #5 of 17 (permalink) Old 04-19-2018, 04:36 PM
First Name: Eric
The AEG OF2025e is the successor model in Europe. Parts may still be available here, but don't expect a speed controller to be cheap
"The person who never made a mistake, never made anything" - Albert Einstein
"I too will something make, And joy in the making" - Robert Bridges, 1844~1930
Job and Knock is offline
post #6 of 17 (permalink) Old 04-23-2018, 05:34 PM
How much money does it pay to put into it? It is a gimmick that nobody else bothered to copy. If the OP is not handy enough or does not want to make the mod. then his options are limited. If he is not going for a cheap fix he might as well buy a good Bosch. It is useless in it's current state
post #7 of 17 (permalink) Old 04-24-2018, 02:55 AM Thread Starter
First Name: Peter
Hi Eric
thanks to you and the other respondants. This router I have has done nearly no work in the 20 years I have had it so now maybe I can sell it for a more modern one or use it in a table like Ron Fox suggested in his report on it.
regards to all
Peteroo
Peteroo1 is offline
post #8 of 17 (permalink) Old 04-27-2018, 02:55 PM
First Name: Eric
I may have the wrong end of this, but are you saying that a speed controller is "a gimmick that nobody else bothered to copy"? If so, I'd have to disagree, as almost every router I've bought new since the mid-1980s has been variable speed.....
Well, providing you don't want to run large diameter bits (e.g. panel raisers or large diameter profile bits) and are content to stick with bits of say 22mm (7/8in) or smaller then the router is certainly still useable, especially for tasks such as mortising, template routing, grooving, cutting housings (dados), etc. The choice is yours.
I have found a parts listing for your router - the distributor in the UK is Spare Tool Parts UK and the listing page is here. Looking at the diagram I can see similarities to the design of the Elu MOF177e (later deWalt DW625 - Elu were the first router maker to produce heavy duty VS plunge routers in about 1979). One thing which struck me is that the RE601 uses a magnetic core (item #36) which seems to be similar to what Elu used to call the "wheel" - a small disc which contains a piece of metal on one side and is used by the router to monitor the spindle speed. In the case of the Elu (and later DW) these can occasionally come loose or detach and cause the variable speed to stop working. The fix is simply to reattach and glue the item in place at the top of the router armature shaft with a spot of Loctite. It may be worth looking into this
BTW I'd be happy to track down the distributors for AEG tools here if you'd like
radios likes this.
post #9 of 17 (permalink) Old 04-27-2018, 04:58 PM
First Name: martin
Searspartsdirect https://www.searspartsdirect.com claims to have parts for anything, check them out..
radios is offline
post #10 of 17 (permalink) Old 04-27-2018, 08:11 PM
Peter if it works perfectly but you can’t fetch a decent price selling it then you might as well use it. There must be a job you could dedicate it to.
Stepper Motor Driver VS stepper motor controller robotdigg CNC Routing 24 03-31-2014 06:46 PM
RYOBI vs SKIL Benchtop Drill Presses BRAVOGOLFTANGO Tools and Woodworking 12 10-22-2012 09:37 AM
Speed controller for PC 7518 Sundlof Table-mounted Routing 4 03-12-2012 07:18 AM
Ryobi Straight Edge Guide doesn't fit Ryobi RE180PL1 Router BabyGerald General Routing 1 09-16-2011 07:31 PM
New router use w/ Ryobi 1801M1 router 1/4 inch collet RexM Router Bits - Types and Usage 1 04-11-2011 04:37 PM
