Birdsmouth joinery - Router Forums
 19Likes
post #1 of 19 (permalink) Old 02-27-2018, 07:06 AM Thread Starter
First Name: BILL
Default Birdsmouth joinery
Wondered if many of you have used birdsmouth joinery bits for your projects and your impression.
Putttn is offline
post #2 of 19 (permalink) Old 02-27-2018, 07:18 AM
yes...
they work well..
LeeValley has a very good set...
Bird's-Mouth Joinery Bits™ - Lee Valley Tools
if you work out the angles you can makw the cuts on the table saw using a dado blade...
post #3 of 19 (permalink) Old 02-27-2018, 07:38 AM Thread Starter
First Name: BILL
I never thought that the table saw with a dado stack would be a alternative but it does make sense. Any advantage/disadvantage or using the tablesaw.
Putttn is offline
post #4 of 19 (permalink) Old 02-27-2018, 10:10 AM
Knothead47's Avatar
Interesting link, stick. Never seen that before.
John T.
Knothead47 is offline
post #5 of 19 (permalink) Old 02-27-2018, 02:18 PM
yes...
they work well..
I saved this article years ago, really liked the look of the finished lamp - wife didn't, enough said. The article shows making the joint with two passes on the TS, but it looks as if one of those bits would be perfect (and a lot easier). But the wife still doesn't like the lamp..............
tomp913 is offline
post #6 of 19 (permalink) Old 02-27-2018, 02:25 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I've made several boxes with birdsmouth bits. They look very good. Check out Dave Henry on you tube to see what can be done with them.
Heres one of mine.
http://www.pbase.com/john_cooper/ima...384/medium.jpg
sunnybob is offline
post #7 of 19 (permalink) Old 02-27-2018, 02:31 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
That link didnt work very well, the pic is way too small, so this is the second try.
sunnybob is offline
post #8 of 19 (permalink) Old 02-27-2018, 02:53 PM
cheaper/faster...
more versatility..
post #9 of 19 (permalink) Old 02-27-2018, 02:54 PM
dado blade..
one pass...
post #10 of 19 (permalink) Old 02-27-2018, 06:27 PM
The angles on a router bit are preset so there is no setup to get right. I have some cheap MLCS ones that I got cheap on ebay but I haven't had a chance to use them yet. After looking at Bob's box he used his for I'm more motivated than I was before.
Danman1957 and Herb Stoops like this.
simultaneous joinery jared dwarshuis General Routing 10 06-24-2014 03:27 PM
box corner joinery almost there Jigs and Fixtures 17 10-15-2012 08:08 AM
Leigh R9PLUS Joinery System and dovetail joints TWheels Jigs and Fixtures 9 05-31-2012 01:05 AM
Birdsmouth Cutters template tom Router Bits - Types and Usage 19 09-21-2006 08:01 PM
Cutting board and dovetail joinery rzaccone Table-mounted Routing 2 05-12-2006 10:14 AM
