Searching for old Craftsman Collet - Router Forums
 2Likes
post #1 of 12 (permalink) Old 02-27-2018, 01:49 PM Thread Starter
smoenkhoff's Avatar
First Name: Sean
Default Searching for old Craftsman Collet
Just recently my 1/4" collet for my Craftsman Model 320.17542 router spun a bit and developed a bur on one of the splines. Now bits do not sit perfectly centered creating a lot of vibration. I've been to Sear's Parts Direct to find the replacement one but they are marked as unavailable and apparently that is the case anywhere I've looked.
Does any one know where I might be able to locate this collet or a suitable replacement. The OEM part number is 355059500.
Thanks,
Sean
smoenkhoff is offline
post #2 of 12 (permalink) Old 02-27-2018, 01:52 PM
vchiarelli's Avatar
First Name: Vince
@smoenkhoff
Welcome to the forums Sean - a quick search found the following item which I think is what you are looking for. Status shows "factory backordered" so you might be out of luck on it. Here's the link anyway:
https://www.ereplacementparts.com/co...p-1079043.html
vchiarelli is offline
post #3 of 12 (permalink) Old 02-27-2018, 02:21 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router foeum.
You would probably have better luck with finding a used one craftsman older unit are hard to find parts for
My advice just replace the router, lot good used one out there!
Thank You John
Semipro is online now
post #4 of 12 (permalink) Old 02-27-2018, 06:33 PM
Sorry Sean but you are unlikely to find one badged as a Sears replacement. A post on another site says it was made by Chervon Power. Maybe a search there will help.
post #5 of 12 (permalink) Old 02-28-2018, 06:57 AM
bob817's Avatar
First Name: Bob (Robert)
Sean, You could try E-Bay might get lucky and can find one being parted out.
Good Luck! Sorry I couldn't help out more.
bob817 is offline
post #6 of 12 (permalink) Old 02-28-2018, 04:15 PM Thread Starter
smoenkhoff's Avatar
First Name: Sean
Default Thanks for Replies!
First, Thanks for all the replies.
I did take a look at the Chervon Power site and noticed that in "2007 Joint Venture with Bosch for bench-tool category". Interestingly the Bosch collet nut assembly looks much like the ones I have. The downside of course is the current replacement assembly uses a larger collet and nut then my 11 year old model.
As luck is running looking at my old blown Craftsman router (previous one) the nut assembly was a little smaller and my neighbor's father's old router, which is even older, appears to be yet smaller. So it appears as time has progressed the collet nut assembly size has increased. I'm thinking my better bet is much like as been recommended is acquire a newer router keeping this one as spare for my 1/2 bits.
Any advise on Porter Cable or Milwaukee models - preferably one that is capable of doing 1/4 and 1/2 inch bits with a plunge and fixed base.
Thanks again!
post #7 of 12 (permalink) Old 02-28-2018, 04:51 PM
vchiarelli's Avatar
First Name: Vince
Sean, I've got an older Porter Cable 690 with both fixed and plunge bases. It does not have soft start or variable speed. I can't speak about Milwaukee as I've never owned one, but I do have a Bosch 1617EVSPK - has both fixed and plunge bases, soft start, variable speed, takes both 1/4 and 1/2 inch bits. It's a great router. I keep the fixed base in a router table as that router also comes with above-table height adjustment and I can easily pull the motor off and put it in the plunge base. I do have several other routers, an older Craftsman, a real old Black and Decker, that I use for small handheld use as well as a trim router.
You can't go wrong with the Bosch - check CPO Outlets, you can get new and refurb for a reasonable price. Here's a link to their Bosch - $219 for the kit is a pretty good price and they offer free shipping.
https://www.cpooutlets.com/bosch-161...efault,pd.html
graeme.c.payne likes this.
post #8 of 12 (permalink) Old 04-19-2018, 09:12 AM
Thanks again!
Do you have a good 1/2" collet for that router? 1/2" to 1/4" reducers are widely available, totally generic, and inexpensive.That gets you around a bad 1/4" collet.
Sent from my SM-G900V using Tapatalk
Mycrossover is offline
post #9 of 12 (permalink) Old 04-19-2018, 10:15 AM
I looked at the picture on ereplacements link that Vince provided and it has a striking resemblance to a Bosch 1617 collet which fits 20 or more other routers including my Hitachi M12V2 and my M12VC.
post #10 of 12 (permalink) Old 04-23-2018, 06:13 AM Thread Starter
smoenkhoff's Avatar
First Name: Sean
Yes, I do have the 1/2 collet for the router. Thanks for the idea.
Thanks for the heads up aboutt he Bosch 1617 collet. I may give that a look also.
Craftsman 1/2" collet jimmiler General Routing 3 01-06-2017 10:21 PM
Searching for a collet? Mike General Routing 12 06-21-2013 07:30 AM
Craftsman Quickrout 1/2" collet adapter lwbox CNC Routing 7 05-01-2011 09:56 PM
Problem with Craftsman router collet barking spider General Routing 4 01-16-2011 08:18 AM
