Best material for templates ? - Router Forums
 13Likes
post #1 of 18 (permalink) Old 03-01-2018, 03:19 AM Thread Starter
First Name: Mark
Default Best material for templates ?
Hi,
I am new to the forum and would like some advice please, I work in a guitar shop and we want to start to make our own Guitar Pickguards.
What is the best material for templates ? I know MDF is very popular for one - off items, but the templates will be used multiple times.
Is Acrylic or Polycarbonate good for a template ? and have them CNC cut so 100% accurate.
Appreciate any advice.
Many thanks, Mark.
marky1275 is offline
post #2 of 18 (permalink) Old 03-01-2018, 03:53 AM
Welcome N/A to Router Forums..
acrylic is nick sensitive and will crack/break...
polycarbonate is good...
Baltic Birch is another good one and it is repairable...
post #3 of 18 (permalink) Old 03-01-2018, 06:27 AM
First Name: Larry
Welcome to the forum N/a
Knot working is offline
post #4 of 18 (permalink) Old 03-01-2018, 06:39 AM
First Name: mary
welcome
marecat3 is online now
post #5 of 18 (permalink) Old 03-01-2018, 08:17 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I usually use 9mm MDF and cover with Laminex as shown. The second template was made from a Laminex covered kitchen door recovered from a roadside skip together with many more. Off-cuts of Laminex can usually be obtained FREE from the skips behind Kitchen/bathroom workshops, with permission of course!
Even with my much used templates the inside edge of the templates has never given me any problems, but iron on edging strip can be used.
peterbata likes this.
Harry
harrysin is offline
post #6 of 18 (permalink) Old 03-01-2018, 08:26 AM
difalkner's Avatar
First Name: David
Welcome to the forum, Mark! When you get a minute go ahead and complete your profile with first name and location - this helps us to help you and will virtually eliminate being called N/a...
While I'm not in a guitar shop, I do work on guitars and have started building acoustic guitars, and I use MDF for most of mine. But I'm sure your volume of work far exceeds mine. Like Stick said, Baltic Birch is repairable and makes good templates. That will probably hold up longer than MDF. You can take it a step further and do what Harry said about covering them. I do seal my MDF templates with a couple of coats of Nitrocellulose sanding sealer and this seems to help them over time.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 18 (permalink) Old 03-01-2018, 03:03 PM Thread Starter
First Name: Mark
Hi everyone ! Thanks so much for the advice, I think Polycarbonate is the way to go and get the templates CNC cut from my PDF files..
I am totally new to routing, never done any woodwork but looking forward to starting.
post #8 of 18 (permalink) Old 03-01-2018, 03:44 PM
If I was going to use it a lot I would make it out of aluminum.
https://www.onlinemetals.com/merchan...915&top_cat=60
Stick486, OttoW and peterbata like this.
Herb Stoops is offline
post #9 of 18 (permalink) Old 03-01-2018, 05:03 PM
now yur talking...
post #10 of 18 (permalink) Old 03-01-2018, 05:04 PM
JOAT's Avatar
First Name: Theo
What everyone else is calling templates, I call masters. I make a perfect one out of 1/2" plywood, glue that to another piece of plywood, rout that, and end up with a perfect 1" thick master. I happen to like plywood, and hate MDF.
Herb Stoops likes this.
JOAT is online now
Best material for building drawers ? RainMan 2.0 Project Plans and How To 157 08-25-2015 02:05 PM
Inlay Material Thickness KomputerMan General Routing 6 10-21-2014 01:39 PM
Trouble initializing material.. or table? JCPowell CNC Routing 0 11-11-2008 08:30 AM
Table top material questions majn555 Table-mounted Routing 18 11-06-2008 09:49 AM
