Miter Saw Recommendation - Router Forums
 35Likes
post #1 of 33 (permalink) Old 03-01-2018, 07:58 PM Thread Starter
First Name: Joe
Default Miter Saw Recommendation
Hi,
I am looking to get a miter saw. I want a sliding one with a bevel. I am thinking about a 10". My budget is around $200 $250 max. Any recommendations for a beginner miter saw?
Also which do you use more miter saw or drill press?
Peace,
Pastorshobby is offline
post #2 of 33 (permalink) Old 03-01-2018, 08:16 PM
JOAT's Avatar
First Name: Theo
Not a clue why you would ask which is used more, mitre saw or drill press, but I use my drill press far more. However, that is because of what I do, so have minimal use for my saw at this time. I am sure that most people use the saw more. On the other hand, want to start some projects soon where I will be using a chainsaw.
JOAT is offline
post #3 of 33 (permalink) Old 03-01-2018, 08:46 PM Thread Starter
First Name: Joe
At this point I have a circular saw and a TS so a miter would be convenient. Whereas, I do not have a drill press. Does that make sense?
post #4 of 33 (permalink) Old 03-01-2018, 08:59 PM
hawkeye10's Avatar
First Name: Don
Joe, I have a Dewalt miter saw and hardly use it. I can do everything on my table saw that I can do on my miter saw. I do use my drill press a lot and my advice would buy a drill press first. I believe it was Tom that bought a When drill press not too long ago and it looks nice. I have a Harbor Freight drill press.
RainMan 2.0 likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 33 (permalink) Old 03-01-2018, 10:08 PM
vchiarelli's Avatar
First Name: Vince
Joe: A table saw combined with a circular saw will do most things that a miter saw will do. None of them will do what a drill press does. Having said that, a portable drill will do most things a drill press will do. It really depends on your needs, the type of work you do or plan on doing. I have a couple of table saws, circ saw (several) a couple of drill press as well as a 12" dual bevel Bosch miter saw. The miter saw really comes in handy when cutting crown moulding, but essentially it's used to break down long pieces which you can do with a circular saw.
vchiarelli is offline
post #6 of 33 (permalink) Old 03-02-2018, 01:41 AM
JOAT's Avatar
First Name: Theo
Me too, and it does exactly what I need it for.
JOAT is offline
post #7 of 33 (permalink) Old 03-02-2018, 08:54 AM
DonkeyHody's Avatar
First Name: Andy
Spend your money on an Incra miter gauge for your tablesaw
https://www.amazon.com/Incra-MITER10...70_&dpSrc=srch
It will transform your crosscutting experience and make you forget about a miter saw until you start cutting really long boards.
DonkeyHody is offline
post #8 of 33 (permalink) Old 03-02-2018, 09:13 AM
Danman1957's Avatar
Vince spoke my thoughts. If you plan on doing some construction I would go with the mitre saw. Do you really need it to slide ? for fine woodworking the non slider is easier to set up and more accurate. If you don't plan on doing any construction, I would go with the drill press. These machines are not very complex so a used one would be easy to inspect for good condition.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #9 of 33 (permalink) Old 03-02-2018, 10:09 AM
First Name: JJ
Harbor Freight has a 10" sliding miter saw usually less than $100 with a coupon.
Flipsaw is offline
post #10 of 33 (permalink) Old 03-03-2018, 06:34 PM
Contributor of the Month
Hi,
Peace,
WOOD magazine did a review of sliding compound miter saws that are in your price range. SEARS model 21237 did well in the review. I bought one on sale for $198 and it's worked well. The problem with sliding miter saws in this price range will be the accuracy of the cuts and the sturdiness/quality of the saw components. As others have said miter saws and drill presses are totally different tools and the amount of usage will depend on the work that you need to do.
JIMMIEM is offline
Miter Set Gauge Jig Bob Adams Jigs and Fixtures 17 09-26-2017 04:50 PM
Accuracy Of Sliding Miter Saw?? Jerry Bowen Lobby 48 07-11-2016 12:55 PM
Crosscut Fences II (Digital) MAFoElffen Tools and Woodworking 10 06-28-2013 08:37 PM
Miter track recommendation ccmnova Table-mounted Routing 11 05-16-2011 10:58 AM
For Sale: Ridgid 12" sliding miter saw - USED, works dovetail_65 Woodworking Classifieds 11 01-20-2011 11:28 PM
