Lock Miter Bit - Router Forums
 13Likes
post #1 of 20 (permalink) Old 03-04-2018, 10:08 PM Thread Starter
pusserboy's Avatar
First Name: Stuart
Default Lock Miter Bit
If you have a lock miter bit for 3/4 " stock can you use it for 1/2 " stock or do I have to buy a new bit.Stuart
pusserboy is offline
post #2 of 20 (permalink) Old 03-04-2018, 10:29 PM
if the bit is rated for that thickness and it'll take a little more finessing bit sure .. go for it...
cheat...
use a rebated rabbet..
post #3 of 20 (permalink) Old 03-04-2018, 10:33 PM
Semipro's Avatar
First Name: John_*
They sale a bit for 1/2” 3/4” and 1” material
Semipro is online now
post #4 of 20 (permalink) Old 03-04-2018, 10:36 PM
he has a bit for ¾ material
post #5 of 20 (permalink) Old 03-05-2018, 01:26 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Yes, you can use the 3/4" bit for 1/2" stock. This is a wonderful joint and once the set-up has been mastered it's hardly more difficult to make than a simple mitre.
Once the set-up is spot on for a particular thickness wood, make and keep a test piece for easy set-up when using that thickness wood in the future.
Gene Howe, JFPNCM, TenGees and 1 others like this.
Harry
harrysin is offline
post #6 of 20 (permalink) Old 03-05-2018, 07:42 AM Thread Starter
pusserboy's Avatar
First Name: Stuart
Thank you all for the replies that will save me some money thats great!
Stuart
post #7 of 20 (permalink) Old 03-05-2018, 09:37 AM
The set up will be different for every thickness you use it for. There is a point on the profile that has to be centred on the thickness of the boards.
Ray Newman likes this.
post #8 of 20 (permalink) Old 03-05-2018, 11:19 AM
Check out the Marc Sommerfeld Easy Set jig. It's made for his brand bits (yellow version) and Freud (red version). The jig has 6 points, each a jig for a different common bit, including the locking miter. It also has a dial to set the thickness of the wood. It costs a bit less than $30 and is very helpful and accurate for setup. Here's a video on how to use it.
I've tried other jigs, but this one is the best so far. You will need to measure the thickness pretty accurately, I use a dial gauge caliper for that.
post #9 of 20 (permalink) Old 03-05-2018, 12:26 PM
Gene Howe's Avatar
First Name: Gene
Tom, his disclaimer states the yellow jig will only work with Sommerfeld bits. Do you use it with other lock miter bits?
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #10 of 20 (permalink) Old 03-05-2018, 12:40 PM
I have the Red ones from Infinity and use with Infinity bits.
Herb Stoops is online now
What lock miter bit would you recommend? adot45 Router Bits - Types and Usage 15 01-25-2015 09:26 AM
45 lock miter routafinger Router Bits - Types and Usage 10 04-13-2011 12:14 AM
Has anyone used a lock miter bit? dustmaster Router Bits - Types and Usage 29 01-30-2011 06:53 AM
Lock miter bit for 3/8' pine lpret Router Bits - Types and Usage 8 04-28-2010 09:31 AM
Making a Zero Clearance Fence for Drawer Lock Bit gerrym526 Table-mounted Routing 7 03-16-2010 09:08 AM
