Plastic - Router Forums
 5Likes
post #1 of 16 (permalink) Old 03-07-2018, 03:37 PM Thread Starter
pusserboy's Avatar
First Name: Stuart
Default Plastic
Just want to know what you have used PVC boards for and pics if you got them
Stuart
pusserboy is offline
post #2 of 16 (permalink) Old 03-07-2018, 05:01 PM
Stuart; you aren't talking about HDPE are you?
https://www.grafixplastics.com/mater...yAAEgKNDPD_BwE
I'm not even sure where to look for PVC in sheet form(?)... Industrial Plastics and Paints maybe:
https://goindustrial.ca/index.php/en/
DaninVan is offline
post #3 of 16 (permalink) Old 03-07-2018, 06:48 PM
First Name: Ken
Stuart, or do you mean the white PVC lumber that HD sells maybe?
hawkeye10 likes this.
kklowell is offline
post #4 of 16 (permalink) Old 03-07-2018, 07:04 PM Thread Starter
pusserboy's Avatar
First Name: Stuart
Kklowell that's right what would that be good for in home woodworking.
Stuart
post #5 of 16 (permalink) Old 03-07-2018, 09:52 PM
HDPE I think is what they make cutting boards from. Some folks use these to cut zero clearance table saw inserts. PVC--never seen it in anything but pipe. Left in the sun, PVC discolors pretty badly.
harrysin likes this.
post #6 of 16 (permalink) Old 03-08-2018, 12:09 AM
I used a piece of expanded PVC to shim a door I installed 3 years ago and it has been fine. However, if I had known it was XPVC when I bought it, I would have used something else. I had to mortise in hinges and it machined with no trouble.
I wouldn't recommend it but it works if you must use it. As for a general wood substitute, how are you going to glue it, regular woodworkers glue isn't going to stick, so you'll have to use ??epoxy??
My application is not exposed to sunlight so UV is not an issue. In addition to discoloring, UV makes PVC brittle causing it to fail easily.
harrysin and Herb Stoops like this.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #7 of 16 (permalink) Old 03-08-2018, 06:32 AM
hawkeye10's Avatar
First Name: Don
I agree and I think it's that plastic lumber that is used for decks. (maybe)
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 16 (permalink) Old 03-08-2018, 06:42 AM
Azek?? or the ilk...
post #9 of 16 (permalink) Old 03-08-2018, 07:09 AM
First Name: Kurt
I’ve used a lot of it outside ..... Brickmold around all the outside doors, framing around the overhead door,
and the risers on these steps.... Several years old and no sign of discoloration..... Great stuff to work with ...
Danman1957 likes this.
Oakwerks is offline
post #10 of 16 (permalink) Old 03-08-2018, 07:19 AM
First Name: Ken
Yes, Azek. The stuff looks like white boards. Costs more than wood does though.
kklowell is offline
Making Pulley Wheels from Plastic Flutemaker Jigs and Fixtures 8 09-01-2016 07:44 PM
Alternative to thin plywood - thin hard plastic? bobbotron Starting Off 10 05-18-2012 11:14 AM
Sears 17543 Plastic Sub Base Plate Problems hungerfo General Routing 8 02-28-2010 08:44 AM
What Router to buy (cutting plastic) stevegriswold General Routing 1 07-03-2005 12:56 PM
