Need suggestions to implement what I am calling a power supply router - Router Forums
 9Likes
post #1 of 13 (permalink) Old 03-08-2018, 09:06 PM Thread Starter
Default Need suggestions to implement what I am calling a power supply router
I am looking for the general approach (technique/strategy, componentry used, etc.) to implement what I am calling a power supply router, although perhaps there is a more precise/accurate term for it.
By "power supply router" (PSR), what I mean is this:
  • A device, say some PCB (doesn't really matter) will connect to this PSR and expect it to be its power supply, but...
  • The PSR itself is not an actual power supply; it is simply a circuit/component/thing that uses a simple routing algorithm to draw power from one of several actual power supplies at any given time
  • In other words, the router will strive to always provide power (if the device is toggled to be "on" via power button, etc.) from one of many power supplies, and can switch the actual power supply it is using at any point in time (only during operation of course) according to this algorithm
And a diagram for illustration:
Need suggestions to implement what I am calling a power supply router-pyiai.png
In that diagram Power Supply #1 (PS1), #2, #3, #4 and #n are the actual power supplies (batteries, solar panels, whatever). The device connects to the router, expecting it to supply it with power, but the router will only be connected to one PS at any given time.
The algorithm I am looking to implement is very simple:
  • For all the power supplies in the system, find the first supply that isn't "nearly dead" and set it as the current supply
  • Once the current supply is nearly dead, obtain the next non-nearly dead supply and set that as the current supply
  • Only when all power supplies are dead/nerly dead is the system officially out of power
I'm sure the "nearly dead" part requires better explanation. Here, the router simply needs to be able to determine whether the given supply is almost dead, perhaps based on the amount of volts or amps its currently outputting, or based on some gas gauging component like what cell phones use to show you that your smart phone is at "2%".
I'm wondering if this type of "routing multiple power supplies" need is a well known pattern in EE, with well known solutions? Either way, what are my options here for implementing such a router & routing algorithm as a circuit? What components could be used?
Thaik is offline
post #2 of 13 (permalink) Old 03-08-2018, 09:58 PM
I agree.
RainMan 2.0 likes this.
Herb Stoops is online now
post #3 of 13 (permalink) Old 03-08-2018, 10:14 PM
JOAT's Avatar
First Name: Theo
I disagree.
JOAT is online now
post #4 of 13 (permalink) Old 03-08-2018, 10:51 PM
Terry Q's Avatar
Me too
Terry Q is offline
post #5 of 13 (permalink) Old 03-08-2018, 10:52 PM
Semipro's Avatar
First Name: John_*
These are wood working routers
Danman1957 and Herb Stoops like this.
Semipro is online now
post #6 of 13 (permalink) Old 03-09-2018, 12:41 AM
First Name: Ray
As an old time electrician told me: "When wring up a circuit --black to brass or you'll burn your arse."
Ray Newman is offline
post #7 of 13 (permalink) Old 03-09-2018, 03:20 AM
And White to silver and green to green. And what about Red? Red to brass?
post #8 of 13 (permalink) Old 03-09-2018, 08:07 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I'm sure we are all on the same page in believing that this gentleman is not talking wood-working routers!
Harry
harrysin is offline
post #9 of 13 (permalink) Old 03-09-2018, 09:45 AM
Red wires are a wonderful thing for controlling a light (for example) from a remote switch.
Herb Stoops likes this.
post #10 of 13 (permalink) Old 03-09-2018, 10:25 AM
MEBCWD's Avatar
Why reinvent the wheel https://www.amazon.com/APC-SmartConn...rotector&psc=1
You can use it on your pcb board and I'll use it on my CNC in case the power goes out.
MEBCWD is offline
Cnc 6040 4 axis power supply issues Andres Perez General Routing 2 11-07-2017 08:46 AM
Need suggestions for new router jnbrown Table-mounted Routing 15 08-18-2014 10:17 AM
Need Advise re Power Supply info for LED lighting gwizz Lobby 29 04-11-2013 08:44 PM
Milwaukee 5625-20 15 Amp 3-1/2-Horsepower Fixed Base Variable Speed Router Review woodrouterreviewsguy Tool Reviews 1 02-23-2012 10:35 PM
