Attn: Aussie craftsmen - Tasmanian Oak query - Router Forums
 6Likes
  • 5 Post By 1fizgig
  • 1 Post By 1fizgig
post #1 of 6 (permalink) Old 03-12-2018, 07:44 PM Thread Starter
1fizgig's Avatar
First Name: Steve
Question Attn: Aussie craftsmen - Tasmanian Oak query
Hi folks.
As some of you may know/remember, I'm building a round dining table with x-legs.
I'm going to use Tasmanian Oak for the legs, and probably a beech top.
The Tassie oak I've gotten are lengths of 2-ply laminate. I've never worked with this wood before, are there any tricks or things I should know before I get started?
I'll be cutting half lap joints for the main joinery. I'm hoping it'll be relatively stable and I plan to use clear poly to seal it once I've got it all cut and assembled.
If anyone has any suggestions or tips, I'd love to hear them.
For our overseas friends, Tasmanian Oak is a hardwood variety taken from 3 Eucalyptus varietals, fairly light colour with some pleasant grain characteristics (to my mind).
I was originally going to use pine, but after discussing with my designer (wife), the plans have changed a little
1fizgig is offline
post #2 of 6 (permalink) Old 03-12-2018, 08:07 PM
Steve that is sure pretty wood. does the reddish coloration go to brown when it is finished? In any event the grain is nice no matter what color it turns. Show pictures of your progress.
Herb Stoops is online now
post #3 of 6 (permalink) Old 03-12-2018, 08:31 PM
jj777746's Avatar
Hi Steve,we have a lot of Tassie Oak in our kitchen & it's really good timber. Although I didn't build any of this kitchen I have used it for other projects & all I can say is go slow,take your time & watch for tear out & splinters. All the best,Jamesjj
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #4 of 6 (permalink) Old 03-13-2018, 03:51 AM Thread Starter
1fizgig's Avatar
First Name: Steve
Default Tassie oak finishing
Hi Herb
I think it will depend on what you finish it with. I have tested a little piece with the clear water-based poly, and it hasn't changed the colour at all really, which was surprising.
I'll definitely show photos!
Just finished the mortising jig today that I will use for the leg joint (will explain as I go along), and the best bit for me is it works! I have to celebrate these things, I'm usually really cautious about these things and need the confidence boost. Feeling good about it so far
Danman1957 likes this.
1fizgig is offline
post #5 of 6 (permalink) Old 03-13-2018, 03:54 AM Thread Starter
1fizgig's Avatar
First Name: Steve
Thumbs up Ah, good to know
Thanks James. I will be taking it easy as I go, although mostly that's for fear of screwing it up.
I appreciate the tips based on your experiences.
I think I see what you mean about the tears. I hand-cut a small piece to try with the poly, and it splintered at the end of the cut (wasn't supported), so I'll have to watch this carefully.
Looking forward to posting progress pictures really soon!
1fizgig is offline
post #6 of 6 (permalink) Old 03-17-2018, 06:27 AM Thread Starter
1fizgig's Avatar
First Name: Steve
Hi James
You were right about the splintering! Just a side note: I found that the same trick to help plywood stop splintering helps on this wood also - a bit of masking tape across the cut and the splintering/tear-outs were almost zero.
I'd recommend trying that next time you're cutting any.
1fizgig is offline
