Do you use a sanding sealer or wood filler in your projects - Router Forums
 8Likes
post #1 of 18 (permalink) Old 03-18-2018, 05:00 PM Thread Starter
First Name: Larry
Default Do you use a sanding sealer or wood filler in your projects
I just finished a Walnut burl for a small table. I put several coats of lacquer and noticed lots of divots.
So I sanded it down to bare wood and used CrystaLac wood grain filler. I have used this several times
before and it works ok. It says it dries Absolutely clear but it dries white but you
can mix it with stains so it will work on most woods. It says its non shrinking but it does shrink. So
my question to you is what do you use as a wood filler or sanding sealer or your cutting boards or
furniture to get a nice smooth finish. The Walnut burl came out very nice the second time.
Knot working is offline
post #2 of 18 (permalink) Old 03-18-2018, 05:10 PM
Larry; the hardwood floor guys have access to stainable wood filler, but it comes in one gallon cans. They trowel it over the whole floor installation, after the first sanding (and vacuuming up of the dust!), thel lay down the filler which fills everything; grain, voids, nail holes, etc.
Then it's finish sanded, stained, and finished. I seem to remember some of the projects being stained and filled at the same time...the filler is very liquid.
https://www.bona.com/en-CA/Professio...acific-Filler/
DaninVan is offline
post #3 of 18 (permalink) Old 03-18-2018, 05:12 PM
for wood filler I like TimberMate and Mohawk for other type fillers and burn in sticks...
for grain fillers it's Behlin..
sanding sealer.. rarely...
been using them for decades and no issues..
Behlin
Timbermate Water-Based Wood Filler
Touch-Up Fillers/Wood Fillers - Mohawk Finishing
jj777746 likes this.
Stick486 is offline
post #4 of 18 (permalink) Old 03-18-2018, 05:51 PM
I started using the stuff in the picture. You can get Timber Mate in a variety of different colors to match the wood you're using BEFORE staining. I find it doesn't shrink. But I don't use it to fill large areas. I generally work it into the workpiece using my fingers to press it in, but if I let it dry, I almost have to sandpaper my fingers to get it off. I also no longer use paper backed sanding medium but use the 3M flexible sanding sheets instead, which seems to last a very long time.
https://www.amazon.com/s/ref=nb_sb_s...te+wood+filler
post #5 of 18 (permalink) Old 03-18-2018, 08:50 PM
Larry; I realized after I made my first comment that you lumped "cutting boards" in with furniture. Only food grade products can be used on cutting boards! Same for little kids toys.
Personally, I wouldn't use anything with an open grain for food prep stuff like boards, trays, or salad bowls. That hopefully eliminates the need for grain fillers(?).
DaninVan is offline
post #6 of 18 (permalink) Old 03-18-2018, 09:48 PM
difalkner's Avatar
First Name: David
I spray Nitrocellulose lacquer on just about everything I do except for the kitchen items - cutting boards, trivets, etc. So 90% of what I produce gets sprayed with sanding sealer and gloss lacquer. I only use pore filler on guitars or something requiring a piano/guitar like high gloss finish.
David
DaninVan, TenGees and jj777746 like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #7 of 18 (permalink) Old 03-18-2018, 11:48 PM
forgot to mention that I do use sanding sealer to raise the fuzz so I can sand or scrape it off.
post #8 of 18 (permalink) Old 03-19-2018, 07:15 AM Thread Starter
First Name: Larry
Thank You all lots of very useful information. Dan I don't use any open or course grain wood for cutting boards.
I do know that Andrei (Mt Wood the cutting board goro) used some sort of grain filler in his cutting boards.
post #9 of 18 (permalink) Old 03-19-2018, 10:05 AM
Honored Member
harrysin's Avatar
First Name: Harry
The only success I've had with Timber Mate is with the Pine coloured one. I normally use thinners based sanding sealer as distinct from the turps based product on open grain timbers. It dries in next to no time so that several coats can be applied if necessary and sanded in between in little time.
Harry
harrysin is offline
post #10 of 18 (permalink) Old 03-19-2018, 10:10 AM
First Name: Gary
I have to ask, When applying sanding sealer...how long do you let it dry before staining, for the best results? Hours, minutes, overnight, days? I have never used it because of this question.
gmercer_48083 is offline
Cabot Sanding Sealer Marco The Finishing Touch 3 02-20-2013 11:26 PM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 05:01 PM
Wood filler S Bolton General Routing 3 05-05-2008 09:57 AM
Best wood filler? Birchwood Tools and Woodworking 4 10-11-2005 08:47 AM
