Router advice please - Router Forums
 26Likes
post #1 of 21 (permalink) Old 03-19-2018, 01:35 PM Thread Starter
Default Router advice please
Hello. New member here. I seem to have lost my best router friend (Pat Warner) and I need some up-to-date advice about a new fixed-base router. I need to get a new router-table router with the best height-control adjustments (meaning: most stable, accurate and easy to set). I use an embarrassingly old and beat up bunch of routers and it's time to graduate.
Also I've read about PC 690s being both good (the 'old' ones) and not-so-good (the 'newer' ones). But how do you tell the difference? Serial number? Body design?
Thanks for any help, Craig Umanoff
cptvideo is offline
post #2 of 21 (permalink) Old 03-19-2018, 02:21 PM
Hey, Craig, welcome!
DaninVan is online now
post #3 of 21 (permalink) Old 03-19-2018, 03:32 PM
welcome Craig..
new old stock is about unheard of.. been too many years..
Bosch 1617 for the table...
post #4 of 21 (permalink) Old 03-19-2018, 03:38 PM
The bosch 1617 you can take the fixed base and remove the phenolic base and mount it under your table plate. You might have to drill a hole in the plate to access the end of the height adjustment shaft to raise and lower it from the table top.
Herb Stoops is online now
post #5 of 21 (permalink) Old 03-19-2018, 04:13 PM
MT Stringer's Avatar
The Triton 3 1/4 hp router is a plunge model but if you remove the spring (per their instructions), you can mount it under a table. The height adjustment can be made through the table with the supplied crank handle. Plenty of power to handle anything you can throw at it.
I have one in a table and a Bosch 1617 on the other end!
Note that I used the Kreg insert plates. They are predrilled so the crank handle and the Bosch hex key can fit through to make height adjustments.
Name:	2014-06-03 17.44.15.jpg
File Type: pdf Bosch 1617 EVSPK Router Combo Kit Description -small.pdf (442.3 KB, 19 views)
MT Stringer is offline
post #6 of 21 (permalink) Old 03-19-2018, 04:59 PM Thread Starter
Thanks, Stick 486, but I meant that if I were looking for an older 'good' PC where is the cut-off from the poorer quality ones and how can you tell 'em apart by looking at them?
cptvideo is offline
post #7 of 21 (permalink) Old 03-19-2018, 06:35 PM
Craig; the point they're making is 'why would you?!'
-Parts will be almost non-existant
-new technology is far superior...soft start, electronic speed controllers, through-the-base ht. adj. just to name three off the top
-service from a lot of these older companies is hit or miss as they've been bought and sold so many times (the companies, not the tools).
-Craftsman is a good example; here in Canada Sears is closing their doors.
Do yourself a huge favor and buy a state of the art machine from a reputable manufacturer who will give you great Customer Service (my vote goes to Bosch).
post #8 of 21 (permalink) Old 03-19-2018, 06:49 PM
Got it... good luck w/ that..
What DaninVan said...
have no fears/worries...
go w/ the Bosch...
CPO Bosch is a good place to start...
post #9 of 21 (permalink) Old 03-19-2018, 09:02 PM
hawkeye10's Avatar
First Name: Don
Here is a link to CPO which is a great company to deal with. I and others have bought from them and they stand 100% behind their products.
https://www.cpooutlets.com/routers-a...efault,sc.html
cptvideo likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 21 (permalink) Old 03-19-2018, 09:24 PM
vchiarelli's Avatar
First Name: Vince
@cptvideo - Craig - I have a PC690 and a Bosch 1617 (both routers are kits, meaning they both have fixed and plunge bases). Quite frankly, the two don't compare. The Bosch is soft start - the router won't jerk out of your hands when you fire it up - the Bosch has speed control; the 690 (an older model) doesn't have those. The Bosch sits in a table in a Kreg insert plate. I had to drill my own holes, so drilled a hole for the above-table adjustment as well.
Go with the Bosch, you won't be disappointed.
vchiarelli is offline
Seeking Advice First Router Project hyped DIY and Renovation 67 04-15-2018 07:32 AM
Seeking advice on where to position router on new table build bigrizz Table-mounted Routing 15 01-08-2018 07:56 PM
Looking for router advice lostintheyard Portable Routing 17 10-14-2013 02:28 PM
Router buying advice welcomed. Joeofalltrades General Routing 12 07-07-2008 10:58 PM
