Walnut Burl table - Router Forums
 11Likes
  • 7 Post By Herb Stoops
  • 3 Post By mark greenbaum
  • 1 Post By Tonto1
post #1 of 8 (permalink) Old 03-19-2018, 04:37 PM Thread Starter
First Name: Larry
Default Walnut Burl table
This is the Walnut Burl table top I had to strip down and do over. Much better
the second time. The top was sprayed with two coats of lacquer, the next day
two more coats, did this for 5 days. Than two coats of urethane for three days
with wet sanding between coats.
Knot working is offline
post #2 of 8 (permalink) Old 03-19-2018, 06:48 PM
Did you use invisible lacquer, or urethane?
Herb Stoops is online now
post #3 of 8 (permalink) Old 03-19-2018, 06:55 PM
looks like your picture didn't post...
post #4 of 8 (permalink) Old 03-20-2018, 08:08 AM
First Name: Quenten
Not nearly so exciting without pictures!
Tonto1 is offline
post #5 of 8 (permalink) Old 03-20-2018, 09:09 AM
First Name: Mark
You could really bang your knees on that table, as transparent as it is!. Everyone is a comedian - we're here all week, folks.
mark greenbaum is offline
post #6 of 8 (permalink) Old 03-20-2018, 02:04 PM
vchiarelli's Avatar
First Name: Vince
I think you did too much rubbing with the last coat - rubbed out the entire table!!!!
vchiarelli is offline
post #7 of 8 (permalink) Old 03-20-2018, 05:49 PM
First Name: Quenten
We refer to that as excessive sanding!
Stick486 likes this.
Tonto1 is offline
post #8 of 8 (permalink) Old 03-21-2018, 09:13 AM
First Name: Barry
If my math is correct, Larry applied 10 coats of Lacquer and 6 coats of urethane. That amount of finish has bent the light around the table top making it invisible. It's not Larry's problem, it's ours.
Barry747 is offline
Add router table with dust collector to your table saw pbriggs8 Project Plans and How To 16 06-02-2016 11:23 PM
Black Walnut Live Edge Console Side Table Billy Boy Show N' Tell 7 06-15-2013 08:04 PM
walnut burl box del schisler Show N' Tell 14 02-04-2009 01:52 PM
Walnut Burl Box Build Along (1st Veneer Project) Nickbee Show N' Tell 38 03-18-2008 05:17 AM
Last table Walnut del schisler Show N' Tell 4 11-14-2006 06:33 PM
