Twisted Cherry boards - Router Forums
 4Likes
  • 2 Post By Cherryville Chuck
  • 2 Post By hawkeye10
post #1 of 6 (permalink) Old 04-09-2018, 03:43 PM Thread Starter
First Name: Larry
Default Twisted Cherry boards
A friend was taking down some trees in her yard and wondered if I wanted the Cherry tree. Of course I said
yes. It was 40' to the first big branch. Unfortunately the bottom 32' was rotten. I ended up with a 8' log.
The tree was taken down early fall, I had it sawed up in 5/4 boards and stacked them in my old shop in the
house. I used 4/4 for the bottom sticker with a dato for the 5 ratchet straps and I kept them tight. I ran
a fan during the day, they are now 7% and twisted. I stacked them the way they were sawed, so it seems
like the whole pile on one corner must have lifted off the floor. I wonder if I had turned every other piece
if this would have helped and maybe some weight on top. I used mineral and bees wax on the ends
and the only splitting I got was 2 heart wood boards.
Knot working is offline
post #2 of 6 (permalink) Old 04-09-2018, 03:59 PM
tons of weight on top of the stack would have been the deciding factor...
24/7 air flow...
consistent temperature also...
wet them..
sticker every layer......
add the weight...
Stick486 is offline
post #3 of 6 (permalink) Old 04-09-2018, 04:12 PM
The tree may have had twisted grain to start with and there may not have been much you can do about it. In this link you can easily see the twist of the tree in the photos. https://www.helpfulgardener.com//for...ic.php?t=33733 If the lumber is dried like Stick suggested it may dry straight but it is possible for it to twist later with humidity changes. It may do better if kilned as the heat softens the lignin and once the lignin cools it tends to stabilize to that profile if it got hot enough to start with. It is possible on larger trees to cut timbers and then angle the timbers so that the saw lines up with the grain but there are heavy losses in recovered volume that way. But it's better than nothing if you can't use it otherwise.
TwoSkies57 and Danman1957 like this.
post #4 of 6 (permalink) Old 04-14-2018, 06:48 AM
hawkeye10's Avatar
First Name: Don
I think for the average Joe drying your own lumber isn't a good idea. It takes a lot of knowhow to dry lumber the right way. I am sure you went to a lot of work and expense to dry that lumber and you got mostly firewood.
I worked at one time a flooring mill and even with all their experience they still had things go wrong.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 6 (permalink) Old 04-14-2018, 07:35 AM
That is about the only way around here,there is no kilns close by. When we had the Belsaw Mill on the farm we used to just stick it and stack it in an open shed. When we used it it had a mildew on it, but that was gone after the planer, The bottom of the pile next to the dirt had some bug holes in it. But this wasn't furniture lumber anyway.
Herb Stoops is online now
post #6 of 6 (permalink) Old 04-16-2018, 05:56 AM Thread Starter
First Name: Larry
Don the wood may be twisted but it is not firewood. I will use every bit of it, and I don’t have a lot invested in it.
I can take the twist out it just takes a little time.
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 11:19 AM
Christmas Gifts - End Grain Cutting Boards vchiarelli Show N' Tell 21 12-15-2016 06:45 PM
Edge Joining Boards patlaw General Routing 26 03-21-2016 03:39 PM
Planing with a Router Gilbear Portable Routing 51 05-17-2012 04:40 PM
What color of stain for cherry Jimmy Ross Lobby 0 03-28-2005 03:18 PM
