RPM of single-speed router - Router Forums
 2Likes
post #1 of 13 (permalink) Old 04-15-2018, 08:55 AM Thread Starter
Default RPM of single-speed router
Hi All,
I have a question. I inherited a single-speed B&D router from the 1980s (barely used, though) and I want to repurpose the motor (new purpose to be determined).
Do those motors use gears to produce 22,000 RPMs? Or is that the RPM of the shaft itself (I call it native speed)? I have not bee able to find that information anywhere.
22,000 strikes me as too fast for anything and I'm not sure how pulleys can help at that speed. Oh, and it not soft-start.
Any input would be appreciated.
Thanks,
Daniel
dpantoin is offline
post #2 of 13 (permalink) Old 04-15-2018, 12:34 PM
No gears. It's armature and field coilds are wired to produce that speed. You can get speed controllers that will allow you to slow it down for other applications. Anytime you start spinning bits more than 1 1/2" in diameter you need to slow the speed down and lots of routers back in that period did not come with an integral controller built in. The separate controllers cam only be used with universal type motors and can not be used with a tool that already has one built in.
post #3 of 13 (permalink) Old 04-15-2018, 05:04 PM
vchiarelli's Avatar
First Name: Vince
Daniel - I have an old B&D router, model 7616 type 4. The label on it shows the speed as 23000 rpm.
vchiarelli is offline
post #4 of 13 (permalink) Old 04-15-2018, 08:26 PM
DonkeyHody's Avatar
First Name: Andy
I think your opportunities to repurpose a router motor are fairly limited. The shaft speed is so high and torque so low that you'd need to gear it down quite a bit to get a speed useful for anything else. These motors don't like to start under load. I think its best use is as a router. Save yourself some grief and find another motor to repurpose.
MEBCWD and gmercer_48083 like this.
We should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore. - Mark Twain
DonkeyHody is offline
post #5 of 13 (permalink) Old 04-16-2018, 09:41 AM
CharleyL's Avatar
First Name: Charley
My old B&D 1970's 1 hp fixed base router is rated for 18,000 RPM. Those with higher speeds tend to be laminate trimmer type routers with less than 1 hp ratings and smaller motor diameters. The one that I have was made and sold for many years and became a DeWalt with a yellow top when B&D began offering Industrial rated tools. I'm not near my shop, so I can't give the model number of it.
Charley
Central North Carolina
CharleyL is online now
post #6 of 13 (permalink) Old 04-16-2018, 02:43 PM
vchiarelli's Avatar
First Name: Vince
Charley - mine is from the mid 70s - labelled as B&D "Best" and rated at 1 HP and 23000 rpm
post #7 of 13 (permalink) Old 04-18-2018, 11:27 PM
I never tried it but if you could find the right flex cable it might make a nice "Foredom" style tool for bigger 1/4" shank stuff. Most flex cables are for drills and can't handle the speed. It might get into places a straight electric die grinder can't and it is a lot more powerful. Ther are no electric rt. angle die grinders.
Sent from my SM-G900V using Tapatalk
Mycrossover is offline
post #8 of 13 (permalink) Old 04-20-2018, 07:05 PM Thread Starter
I was going by memory when I posted the message. It turns out that the router's speed is 25,000 RPM. The model is B&D 7516-04 Type 1, 120V, 8.5 Amps (1.3 HP, I guess).
Daniel
dpantoin is offline
post #9 of 13 (permalink) Old 04-20-2018, 07:16 PM Thread Starter
Would a basic router from that era have a universal motor? My limited knowledge of power tool motors would tell me it is, but I wonder. As I mentioned elsewhere, the model is B&D 7615-04 Type 1.
Also, isn't there something about damaging motors that were not built to be run at slower speeds? Or is that precisely what the separate controller would take care of? Even then I think there's a limit to how slow motors can be run even if they're meant to be. (For ex. my Makita 1.25HP owner's manual specifies not to use it at 10,000 RPM too much even though it can go down to that speed if needed.)
I'm a newbie when it comes to electric motors and what I've read/seen about them amounts to a steep learning curve. My interest in motors in an interest in building new machines (bandsaw, larger lathe, disc sander) that could get expensive if purchased new (or even used).
Daniel
dpantoin is offline
post #10 of 13 (permalink) Old 04-20-2018, 07:22 PM Thread Starter
Yes, I'm not all that optimistic at this point. But at 25,000 RPM, I find it hard not to burn the wood, except by moving really fast along the workpiece (safety issue).
D
dpantoin is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
speed adjustment on router dpbrown General Routing 7 11-28-2011 07:53 AM
Variable Speed Plunge Router Application MJCookSr Table-mounted Routing 2 10-22-2010 05:54 AM
True Router Speed bobj3 General Routing 6 09-07-2010 11:23 AM
