Bosch POF 52 compatible plunge base? - Router Forums
 3Likes
  • 2 Post By Job and Knock
  • 1 Post By Job and Knock
post #1 of 9 (permalink) Old 04-24-2018, 07:31 AM Thread Starter
First Name: Andrei
Default Bosch POF 52 compatible plunge base?
Hi folks,
I'm new to this forum.
Quick question re Bosch POF 52.
I obtained a POF 52 very cheap. Works absolutely lovely, no sparks, no smells. Only problem is the old plunge base is 99% unusable- badly cracked- one handle reduced only to the threaded attachment bolt, second handle (I presume functions as the plunge lock?) completely smashed off and missing.
Have located a person selling a second-hand POF 50 with complete plunge base- would that be a compatible base for the POF 52?
Sub-question: What Bosch router parts are generally compatible with the POF 52?
Cheers
Djuka is offline
post #2 of 9 (permalink) Old 04-24-2018, 07:59 AM
welcome N/A...
what country do you reside in...
it matters...
post #3 of 9 (permalink) Old 04-24-2018, 02:27 PM Thread Starter
First Name: Andrei
Hi,
Sorry I didn't clarify. I'm in Sydney, Australia
Djuka is offline
post #4 of 9 (permalink) Old 04-24-2018, 05:43 PM
One way you might be able to tell is to compare part numbers for the base from each model. If Bosch used the same base they would most likely have the same part number.
post #5 of 9 (permalink) Old 04-24-2018, 07:53 PM Thread Starter
First Name: Andrei
Very logical approach, i'll try that.
Thanks!
Andrei
Djuka is offline
post #6 of 9 (permalink) Old 04-27-2018, 03:13 PM
First Name: Eric
Yes. The POF52 was an updated version of the POF50 with a different collet, etc. There was also an "industrial" version (a "blue" one) called the GOF600 and later on there was a compatible laminate trimmer, the original GKF600 (sold in the USA as the model 1608 and 1609). All these tools have one very useful feature in common - the bottom of the motor has a 43mm "neck", the same diameter as most European-made drills. What that means is that the motors and bases are interchangeable. It also means that you can mount the motor in many drill presses and used with a home-made base and fence to make an overhead router table.
Cherryville Chuck and Djuka like this.
"The person who never made a mistake, never made anything" - Albert Einstein
"I too will something make, And joy in the making" - Robert Bridges, 1844~1930
Job and Knock is offline
post #7 of 9 (permalink) Old 04-27-2018, 04:43 PM
First Name: Eric
Just to add a thought to my earlier post - there are several non-Bosch routers which have that 43mm "neck", e.g Hitachi FM8, Kress, Metabo OFe738, etc. So the OP has a few options (see also the Trend compatibility guide)
Djuka likes this.
post #8 of 9 (permalink) Old 04-28-2018, 12:13 PM Thread Starter
First Name: Andrei
Thanks a ton! Very useful info. Gives me something to work with.
Djuka is offline
post #9 of 9 (permalink) Old 04-29-2018, 11:01 AM
First Name: Eric
Another maybe - Black & Decker once did a basic plunge router called the BD66 over here. They were a bit plasticky, especially the base, but they too had a 43mm "neck". You sometimes see them at car boot sales (our equivalent to yard sales over here in the UK, I suppose) for a few pounds
Bosch 23EVP plunge base issues scottkaye General Routing 4 04-04-2017 11:17 AM
Plunge base for DWP611 router? jldmor Site Help and Suggestions 3 02-03-2016 09:29 AM
Bosch Colt Plunge Base Ben in Cypress Texas Portable Routing 5 05-18-2013 10:10 PM
Bosch MR 23 and Milescraft Turnlock base? achoox4 Guide Bushings and Templates 9 04-10-2013 05:48 AM
