Craftsman 2-1/2HP Digital Controled Router - Router Forums
 5Likes
post #1 of 14 (permalink) Old 05-06-2018, 11:08 AM Thread Starter
First Name: Doug
Default Craftsman 2-1/2HP Digital Controled Router
Has anyone here worked on or modified a Craftsman 2-1/2HP digital display/control model 50429 router?
The reason I ask, Is because I can get a (display/floor model) at a local Sears store fairly cheap due to the fact that they are discontinued!
I was thinking it may be possible to cut-out the display/controller panel from the top cover & then relocate it to a table mounted location?
Two things I figure could be a problem, Is if the upper bearing was some how held in-place by the top cover? And if the display/controller & wiring was molded into the top cover with no loose wires to be able to make a jumper from?
Name:	Craftsman 50429 Router 1.jpg
Name:	Craftsman 50429 Router 2.jpg
dwall174 is offline
post #2 of 14 (permalink) Old 05-06-2018, 11:24 AM
Where will you get parts from down the road, Doug?
Just me, but you couldn't give me a discontinued tool...from a source that's going under.
It's NOT a bargain.
Herb Stoops likes this.
DaninVan is offline
post #3 of 14 (permalink) Old 05-06-2018, 01:49 PM Thread Starter
First Name: Doug
Yeah that's a good question! And I've thought about it also.
I'm pretty sure that 50429 is not the full model# And I wasn't able to find anything on-line with that model#.
I do know that Menards still sells one just like it under their Masterforce brand!
Looks identical to the Craftsman, But with a green cover & the Masterforce label.
It's probably made by one of those overseas manufactures that make products for several different store brands.
I would imagine parts would still be available for the router, But figuring out who makes it & getting parts would probably be a PITA
DaninVan likes this.
dwall174 is offline
post #4 of 14 (permalink) Old 05-06-2018, 06:06 PM
The digital display is mostly a gimmick in my opinion. It’s an unnecessary part that can fail and may be difficult to work around should it fail.
post #5 of 14 (permalink) Old 05-07-2018, 08:11 AM
TenGees's Avatar
First Name: Paul
Doug, that's the same as a Mastercraft (Canadian Tire) router that I was given to do a job for a buddy. Mine only has a plunge base and no case and it has worked fine for me. I recently put it in my table but I haven't figured out how to take the plunge springs out (doesn't look easy). That makes the above table height adjustment kinda useless, because it's stiff and racks as you try adjusting it. I like your idea of making the controller remote. I think the digital display is gone on their newer model, maybe the controller was troublesome. I agree with Chuck that it's mostly a gimmick. The soft start is nice in the table though.
Bottom line: I wouldn't buy that for table use. The speed control is awkward upside down, the springs look difficult to remove and the controller is changed on the newer version. I think the above-table height adjuster is gone now too.
I looked at the parts diagram and it looks like the controller/display doesn't have wires.
Name:	Mastercraft Digital Plunge Router 054 6902 0 Parts.png
TenGees is offline
post #6 of 14 (permalink) Old 05-07-2018, 10:52 AM
Under all those bells and whistles is a regular brush type universal motor that is in virtually every router You can see it in the diagram. Since you don't have a part number that shows the vendor code in the first three digits, we don't know who made it but Ryobi, 315.xxxxx made many of the Sears routers. I think there is another thread in this forum and the OP does have the model number for what looks like the same router and the same problem. The only workable solution is to attach the leads from the motor to the line cord and use an external speed control. There are many available from HF to Rockler to the one I have, the heavy duty one from MLCS. In a router table the external control would not even be awkward.
Sent from my SM-G900V using Tapatalk
Mycrossover is offline
post #7 of 14 (permalink) Old 05-07-2018, 11:56 AM
Since the digital controller controls only the speed, what would be gained moving the display/controls to a box external to the router?
If you could set the depth of cut digitally, I could see putting it in a table and moving the display/controls to an external location, but only speed?
Mycrossover likes this.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #8 of 14 (permalink) Old 05-07-2018, 01:03 PM
I have explained this as simply as I can. Every other router in the world works fine without this nonsense. Lets try this.
1 You have a router with a bad digital display/ control.
2 A replacement is probably not available
Choices: 1 Throw router away
2 Spend the rest of your life
looking for the part
3 Use an external speed control
that will allow router to function
like virtually every other router
that manages without this
feature.
What is your point? Are you offering to go to his house and fix his router? You have not offered anything to get him up and running beyond repeating some stuff you found on the net. He needs a solution, not a lesson in electronics.
post #9 of 14 (permalink) Old 05-07-2018, 03:44 PM
Harshly put, but unfortunately brutally to the point.
Cheapest solution is buy a hand held device...
https://www.amazon.ca/Digital-Photo-...ds=tachometers
Obviously doesn't control the speed but it'll put you on target for the speed you're looking for.
MYB506 likes this.
DaninVan is offline
post #10 of 14 (permalink) Old 05-07-2018, 08:25 PM Thread Starter
First Name: Doug
I normally use a Bosch 1617EVS in my router table & the speed control is kind of awkward to get at while in the table.
Basically what I was thinking of is building a low cost version of a Jessem Pow-R-Tek Motor
dwall174 is offline
Router Craftsman 1 1/2hp router, model 315.175140 david cooksey Craftsman Manuals 0 06-28-2011 03:44 AM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
