PC 1002 Router how to disassemble??? - Router Forums
post #1 of 6 (permalink) Old 05-14-2018, 11:36 PM Thread Starter
Default PC 1002 Router how to disassemble???
Need to replace power cord but can't get head off to do it. Have removed the two long screws that hold everything together according to schematic. Also removed two screws above the fan assembly and the brushes. The head is still firmly attached to the main body. No screw on the head cap itself as on the newer routers
roverhi is offline
post #2 of 6 (permalink) Old 05-15-2018, 11:51 AM
TenGees's Avatar
First Name: Paul
I'm not familiar with that router but I have run into the brushes holding onto the commutator when disassembling tools, especially where they've carved a rut in the comm. Remove the brushes if you haven't already. The only other thing I see is the 'Ring' #209 (C-clip thing).
TenGees is offline
post #3 of 6 (permalink) Old 01-28-2019, 01:30 AM
Did you ever have any luck with this?
newparade is offline
post #4 of 6 (permalink) Old 01-28-2019, 05:50 AM
I am also facing a similar issue related to my router. I have also checked the I am also facing a similar issue related to my router. I have also checked the Facebook page but didn't get an appropriate answer. page but didn't get an appropriate answer.
lj962500 is offline
post #5 of 6 (permalink) Old 01-29-2019, 04:39 PM
Knothead47's Avatar
Youtube?
John T.
Knothead47 is offline
post #6 of 6 (permalink) Old 01-30-2019, 04:01 PM
kolias's Avatar
First Name: Nicolas
Had to do something similar, I just cut the cord 2" away from the body and spliced a new and longer cord to it.
Nicolas
kolias is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 06:40 PM
Router Backup yuva New Member Introductions 6 01-21-2014 09:33 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 03:20 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
