Newbie question : Makita M3600G vs Ryobi RRT1600-S - which one would be better? - Router Forums
 6Likes
post #1 of 23 (permalink) Old 05-30-2018, 08:52 PM Thread Starter
First Name: Doug
Default Newbie question : Makita M3600G vs Ryobi RRT1600-S - which one would be better?
Hi all,
I've spent a bit of time searching the forum before posting this, so I thought I'd throw it out to any of you veterans out there. Apologies if this is not in the right forum (Mods, feel free to move it to right right spot)
Anyway, I'm just starting out with routing, but I'm the type who would rather research first before jumping in. I'm just a woodworking hobbyist/DIY, so I don't need top of the line tools...yet.
Anyway, I'm in the process of buying my first router and I need some advice/opinions on which model to purchase. I've narrowed it down to the following two models:
The Makita M3600G - $159 (From Mitre10)
Or
The Ryobi RRT1600-S - $149 (from Bunnings)
(I'd post a link to these, but I don't have enough posts up yet)
The price difference is only about $10, so price is not really a deciding factor here. From what I've learnt, these are mid-range for a DIY type person. I've seen one thread that compared the Ryobi to a Bosch 1/4" one, and hands-down, the Bosch was voted the better one; however, I'm after a 1/2" router.
So, has anyone heard much about the Makita one? I've been searching everywhere online for some sort of review (especially on YouTube), but there doesn't seem to be much on at all. I've been told that Makita is very reliable, but does this also apply to their MT series?
The way I see it, each one has its good points in terms of purchasing:
Makita
- reliable brand name
- buying from Mitre10 looks pretty safe (400 stores in Australia)
- good price
- seems to include a lot of good accessories (ie guides, straight edges, etc)
Ryobi
- easy to purchase from Bunnings
- a tad cheaper ($10)
- I have Ryobi drills and driver and circ saw, and have never had a problem with them
- Ryobi are offering a 4 year warranty with all corded tools (registering them online)
So, for a hobbyist/DIYer like myself, which way should I go?
Anyone's help would be appreciated.
Regards,
DiverDoug
"If you live for the acceptance of others, you'll die from their rejection..."
DiverDoug is offline
post #2 of 23 (permalink) Old 05-30-2018, 09:36 PM
Whichever you choose, consider getting one with a half inch (12mm) collet. You can get a 1/4 inch collet for it. Get a full power (2.25 hp) rather than a smaller 1hp trim router. The smaller router is handy for limited use, but not up to things you'll do later.
Make sure the kit includes a plunge type base, it will cost a lot more to buy it separately later rather than getting the kit.
I don't have many Makita tools, but the ones I have are OK.
If you plan to use this in a table, I would think several times about Bosch. The 1617 is what we have in the USA, but there is an equivalent in OZ, just don't recall the model number. The Bosch fixed base can be used in a table.
Table routing is much safer in general than freehand. And all you need is a flat chunk of ply and a straight pine board to use as a fence. That will get you going and you can add to it later rather than pony up lots of money for a commercial table. You may be able to find a second hand table or dresser you can use for your table.
Bosch has a small handle that will allow you to adjust bit height. It must be purchased separately but is inexpensive. Picture attached of the Bosch setup.
As with many others here, I am a real fan of Bosch. Nothing against most other brands, but I can vouch for the value, ruggedness and quality of Bosch from personal experience. But soon, others will speak up about their choice of router, so you'll get a well rounded set of recommendations.
DesertRatTom is online now
post #3 of 23 (permalink) Old 05-30-2018, 10:43 PM Thread Starter
First Name: Doug
Thanks for that. I had a search online and according to Bosch's aussie website, there's only one table/plunge router available and it's about $530, so that's waaaaay past my budget at this point. If I was looking at becoming a cabinet maker, then it's something I'd consider. The only other non-trim router from Bosch that I could find was the POF 1200 AE. It seems to have got some high praise here, but it is only a 1/4" collet and 1200W motor.
From what I've found, the Ryobi is a 2HP one with a 1/2" collet, so it appears to have a bit of grunt behind it. It is also multispeed, which I'm sure will be handy for different types of cuts. The Makita is 50w more powerful and has a 60mm plunge depth (vs 55mm with the Ryobi), but is about 2kg heavier and only one speed (22,000 rpm).
I do intend to set up a router table, although I can buy a cheap one for only $55 from where I'd buy the Ryobi from. Then again, I also like the challenge of buildign one myself, and there's a huge number of YT vids to get ideas from.
Thanks again for your input!
Diver Doug
post #4 of 23 (permalink) Old 05-31-2018, 04:16 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I have three makita routers, one bosch, and 1 powerplus.
The powerplus is absolute rubbish though.
I have a 1/2" makita in a table and it is absolutely faultless, even without variable speed (and bear in mind that if you fit a variable speed router in a table you either have to crawl underneath each time you want to adjust, or buy a complicated remote speed control).
I have a ryobi mitre saw, and the quality of that is not up to makita.
sunnybob is offline
post #5 of 23 (permalink) Old 05-31-2018, 07:05 AM
Nickp's Avatar
First Name: Nick
My choice would be for the variable speed...you will need it for different bit sizes and woods/materials...
I would consider variable speed a discriminating factor.
If you decide on the Makita, you should be able to get an external speed control.
Good luck...
Nick
Nickp is online now
post #6 of 23 (permalink) Old 05-31-2018, 08:44 AM
Harry Sinclair is one our most experienced “routologists” (his expression) and he lives in Perth and his weapons of choice are Makita. I might add that my main routers are Hitachi and I know that some at least are made in the same factory as the same model Makita. Forget the 50 Watts difference. That part is virtually inconsequential.
post #7 of 23 (permalink) Old 05-31-2018, 10:11 AM
Somewhere along the line, I got a simple external speed control, then learned that the Bosch has it built in. It is really just a rheostat. The speed control is needed mostly to reduce RPMs when you're using a larger bit, which should have a half inch shank.
post #8 of 23 (permalink) Old 05-31-2018, 11:18 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I know the theory of variable speed, but in practice I use my makita RP1801 fixed speed in the table. I use every bit from a 3 mm straight double flute, to a trend box joint cutter
https://www.trenddirectuk.com/866x1-2tc
in woods as different as soft construction timber to all the hardwoods like indian rosewood, bubinga, teak, walnut, beech, zebrano, etc, etc, and I have never had any problem.
Even the yonico birdmouth cutter,
https://www.amazon.com/Yonico-15137-.../dp/B00KZM26YG
which is a fair weight of metal, works perfectly, even if it does make a really impressive wind roar noise.
Sometimes its worth it to just suck it and see.
sunnybob is offline
post #9 of 23 (permalink) Old 06-01-2018, 08:49 PM
Hypnotoad's Avatar
First Name: Phillip
Originally Posted by DiverDoug View Post
Hi all,
Makita
- good price
Ryobi
Regards,
DiverDoug
Doug,
I have just gone through the same thing, I wanted a decent powered 1/2" router which was cheap, (didn't want to pay $400 - $500), so I narrowed it down to the same two or a used Hitachi TR-12 which are getting long in the tooth now.
I looked at the Ryobi, which seems like a toy to me, and the Makita seemed very well made, so I purchased the Makita from TotalTools for the same price you have seen, it's the same every where.
It will roar through everything I throw at it, the collet has no play at all, it has spindle lock and comes with a Makita 1/2" straight bit, 1/4" reducer sleeve, straight guide and a circular guide etc.
It's single speed but if you won't be using bits larger than 30mm diameter the 22,000rpm no load speed is fine IMO (I have tried it with a lock mitre bit and cut fine as well). No soft start but mine is in a router table so no problem with that either. I plan to build a Silicon Chip soft start speed controller later on so that won't be a problem with larger bits either.
The only bad things about this router is that plunge mechanism can bind, this is if you push down on one handle only it will tend to bind a bit, it won't if you press down on both handles or even gently press on the top with one handle, the springs in the Makita are not nearly as strong as my Bosch router which I put down as the cause of this. I have a lift in my table so it's not a problem for me and wouldn't be a problem using it free hand. The other thing for using it free hand is that it has a switch like the older Makita's and the Hitachi TR-12, so you can turn it on and leave it on, which is fine for table use, on my Bosch you have to press in a button and pull the trigger switch to get it to work, which is an extra safety feature.
Overall though, the Makita M3600G is a bargain IMO, great power, no comparison to my 1200watt Bosch (either Bosch are overstating or Makita are understating theirs), seems like double that to me, solid build, great depth adjustment. For that money I wouldn't hesitate buying one again.
https://www.totaltools.com.au/109044...-router-m3600g
No Affiliation
DesertRatTom likes this.
Tight fisted old so-and-so!
Hypnotoad is offline
post #10 of 23 (permalink) Old 06-02-2018, 10:12 PM
First Name: Orlando
If possible or feasible, I would recommend the DeWalt 618PK, Bosch 1617EVSPK, or the Porter Cable 895PK. They all are 2.25HP, have EVS, come with 1/4" (6mm) and 1/2" (12mm) collets, and come with a fixed base and plunge bases so you have the flexibility to do multiple routing applications. I use the PC for some light router table work. Be careful of the slippery slope. I started with the PC 690 fixed base router and now I have it as well as the PC 895PK, DW 618PK, DW 621, DW 625, Milwaukee 5625, and Bosch Colt PR-20. I no longer have the Bosch because someone made me an offer I couldn't refuse for it.
OBG65 is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Newbie end grain question steamingbill Woodturning and Lathes 3 06-03-2013 09:28 PM
A Couple Newbie Question sheperd80 Guide Bushings and Templates 7 03-25-2013 09:30 AM
newbie question falcn63 Table-mounted Routing 1 01-24-2006 10:23 PM
Newbie question on router mounting WallyB Table-mounted Routing 5 06-06-2005 09:20 AM
Newbie Question Billzhere Tools and Woodworking 4 02-14-2005 03:08 PM
