Cannot get motor back into Ryobi R163 - Router Forums
 5Likes
post #1 of 12 (permalink) Old 06-07-2018, 07:32 PM Thread Starter
First Name: Paul
Default Cannot get motor back into Ryobi R163
I have a Ryobi 163 router. While attempting to fix a problem with the collet (depth too short), I removed the motor. When I was trying to put the motor back in, I inadvertently rotated it to the wrong position. (I misinterpreted the position of the arrow on the rotor body.) Now I can only get it partway back out. it seems limited by something solid when I get it just far in enough to line up the arrow on the motor with top of the frame surrounding the depth adjuster. Is there any hope to rescue this otherwise fine router, or do I just have to buy a new one?
Paul
pwabrahams is offline
post #2 of 12 (permalink) Old 06-08-2018, 08:32 AM
TenGees's Avatar
First Name: Paul
Paul, I'm not familiar with that particular router. Just some thoughts: Usually when you align the arrow, you are aligning a pin on the inside of the base with a groove in the motor. Did you try loosening the lock lever adjustment screw? The manual indicates that the spindle lock has something to do with removing and installing the motor. Page 6 and 7 of the manual (on this site) discuss this. I guess the spindle lock lever may hit on something as the base is removed or installed.
If you buy a new one, you can recycle the old one by sending it to me.
harrysin likes this.
TenGees is online now
post #3 of 12 (permalink) Old 06-08-2018, 09:02 AM
First Name: Gary
Paul, Here is the manual...Page 10 tells how to.
harrysin and DesertRatTom like this.
gmercer_48083 is online now
post #4 of 12 (permalink) Old 06-08-2018, 10:44 AM
The Forum comes through again. I think the lock lever is the likely suspect.
DesertRatTom is online now
post #5 of 12 (permalink) Old 06-08-2018, 01:35 PM Thread Starter
First Name: Paul
Angry Can't get tab into keyway
I do have the relevant pages of the manual and they seem to show all the relevant mechanisms.
The task was made more difficult because the router was mounted in a router table and also had a dust collecting cup installed. But I've removed all that and I'm now down to the basic router, nothing else attached. I've also removed all the tension on the lock lever, so it appears that the only thing that's preventing me from removing the motor from the base is the tension within the base itself. After a lot of fiddling I've gotten to the point where the arrow on the motor is within half an inch of the keyway where it belongs.
But that damned tab on the motor -- perhaps 1/32" thick -- butts up against the frame of the base. If I could relieve the tension within that frame, I could rotate the motor to align the arrow with the keyway and I'd be home free. Bur it seems to be pretty solid metal, and I've freed up all the locking levers that I can locate.
So near and yet so far.
And I appreciate the advice I've gottten so far.
post #6 of 12 (permalink) Old 06-08-2018, 08:36 PM
TenGees's Avatar
First Name: Paul
I would remove the lock lever screw completely. Then try to slide the motor out. Turning the motor in place could possibly damage the groove. The spindle lock button needs to be held in (as if you want to remove a bit) or the motor won't come out of the base (I think, from looking at the manual). If absolutely necessary I would gently and slightly pry the slot under the lock lever to loosen the base's hold on the motor, you don't want to distort the base. Maybe a flat screwdriver tapped a bit into that crack would work. If you get it out, you may have to file or sandpaper any damage on the motor or the inside of the base. Fixing the groove would be very hard, that's why I wouldn't try to turn the motor onto the pin. Whereas a scratch on the motor elsewhere could more easily be cleaned up.
Good luck
post #7 of 12 (permalink) Old 06-08-2018, 11:07 PM Thread Starter
First Name: Paul
I finally got the motor separated. You were right; counterintuitively, pushing the spindle lock lever in seemed to do the trick. Thanks!
post #8 of 12 (permalink) Old 06-09-2018, 07:22 AM
First Name: Gary
I wonder if a complaint is in order to RYOBI. here is the link.
https://gethuman.com/phone-number/Ryobi
post #9 of 12 (permalink) Old 06-09-2018, 05:51 PM
TenGees's Avatar
First Name: Paul
Too bad that you got it fixed... I was kinda hoping to get it for recycling.
DesertRatTom likes this.
post #10 of 12 (permalink) Old 06-09-2018, 08:30 PM
Phew, what a relief. I too was pullin' for you.
TenGees likes this.
Ryobi R163 guide bushing adapter plate lmikekelly Guide Bushings and Templates 23 02-25-2020 08:52 AM
Max power draw for Ryobi R163 ?? BobMcK General Routing 31 03-14-2015 05:08 PM
Router Ryobi R163 Router BobMcK Ryobi Manuals 0 03-09-2015 08:35 AM
Ryobi Router R163 thomaslyons General Routing 4 10-05-2014 08:17 AM
Ryobi R163 Dovetail bushing p3auul Guide Bushings and Templates 3 01-03-2012 05:39 PM
