Router bit problem. - Router Forums
 2Likes
  • 2 Post By Stick486
post #1 of 5 (permalink) Old 06-11-2018, 12:56 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Router bit problem.
I have three Whiteside router bits that have chips on the end. They are solid carbide up cut bits. The wood I have been cutting is all hardwood and Russian birch grade 3/B.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 5 (permalink) Old 06-11-2018, 01:24 PM
Call Whiteside about this...
post #3 of 5 (permalink) Old 06-11-2018, 04:05 PM
They might offer to take them back and resharpen to get the chips out.
post #4 of 5 (permalink) Old 06-11-2018, 10:08 PM Thread Starter
hawkeye10's Avatar
First Name: Don
I thought it might be something I was doing. I wish I could find out what causing the chip out so I can fix it. I will call WS and see what they say.
post #5 of 5 (permalink) Old 06-11-2018, 10:57 PM
resonation/vibration/run out can do it..
something that you see w/ cheapo bits or a bearing getting ready to give it up...
check for shaft play and/or run out...
since solid carbide bits can be fragile/brittle ''chatter'' can be detrimental...
bcfunburst and sreilly like this.
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
