Shutters - Router Forums
 10Likes
post #1 of 15 (permalink) Old 06-22-2018, 03:39 PM Thread Starter
pusserboy's Avatar
First Name: Stuart
Default Shutters
I have a 1970 prefab home and now the shutters are beginning to rot out and I would like to make my own.
Now the story is when they built the house they put on the shutters before putting on the aluminum siding and when I take out the shutters there will be a hole.
My question is has anyone ever had to do this that could give me some hints and the depth of the hole would be 2" deep, would there be a U tube video that anyone knows of.
Thanks all.
Stuart
pusserboy is offline
post #2 of 15 (permalink) Old 06-22-2018, 03:53 PM
Stuart; my concern would be water ingression from the space that was left un-sided. If in fact it's nicely sealed by the original construction. Why is it so deep? Is there strapping under the Aluminum siding, on top of the original construction?
That's actually a good thing; that's the same as a modern 'rainscreen' (mandatory now).
I think I'd just go with 'BlueSkin' then 2x2 vertical strapping and whatever extra is required to come up flush with the top of the siding, then shutters to overlap the siding slightly.
Again, I'm curious as to why the siding construct is so deep?
Is there some type of panel insulation or something backing up the siding?
DaninVan is online now
post #3 of 15 (permalink) Old 06-22-2018, 04:13 PM Thread Starter
pusserboy's Avatar
First Name: Stuart
Danon Van thanks for your reply but I've not taken off the old ones yet but I stuck a small screw driver in and it sank 2".
I know that I will have to waterproof if the is none. I was just wondered if anyone else ran into this and what they did.
Stuart
post #4 of 15 (permalink) Old 06-22-2018, 08:13 PM
Take one off, get some pics to show us, and we'll be better able to give you GOOD advice!
Seriously though, I'm not happy that there's a void behind the shutters; that's just not sound building practice.
Herb Stoops likes this.
post #5 of 15 (permalink) Old 06-22-2018, 10:18 PM
I had to remove the shutters on my previous house and the shutter was nailed to the plywood sheathing and the cedar siding was butted to the shutter. There was a tarpaper water barrier under the shutter, and the shutter was caulked to the siding.
The shutters were 1 1/2" thick and the lap siding was 3/4" that butted to them.
DaninVan likes this.
Herb Stoops is online now
post #6 of 15 (permalink) Old 06-23-2018, 10:22 AM
Our house is stucco and the shutters are on top of that; no voids. The annoying thing is the mud wasps like to go in though the louvers and build nests in behind.
The Wisteria 'vines' like to get in there as well.
post #7 of 15 (permalink) Old 06-23-2018, 12:55 PM
Stucco? In B.C.? on Vancouver Isl.? An old Spanish Fort? Is there a Terra Cotta roof too? And Bears?
My shutters were decorative only and had closed louvers, or the critters would have lived behind them too. I removed them when I had new vinyl windows installed and they did the new flashing technique and ruff sawn wood 1 x 6 trim and filled in with new siding where the shutter was located.
I seen later where they had plastic shutters that were cheaper and low maintainance, and I could have went that route.
post #8 of 15 (permalink) Old 06-23-2018, 02:45 PM
We're on the Sunshine Coast; part of the Mainland, not Van. Is.. No terra cotta tile roof.
post #9 of 15 (permalink) Old 06-23-2018, 08:00 PM
Nice house and beautiful yard,I see where you spend your time. I like the long overhang on the roof too. Yours has a trim board over the windows, which mine didn't, I like yours better,
post #10 of 15 (permalink) Old 06-24-2018, 12:59 PM
Thank you, Herb! Tiny portion of the 1/2 acre of landscaping. Good thing I like yard work...
I posted the pic because it has the Wisteria heading up the left-middle shutter.
Project: Window shutters Knothead47 General Routing 7 03-23-2017 01:43 PM
Repair of louvers on outside wooden shutters rorotidwell General Routing 5 11-04-2011 02:54 PM
louvered shutters markpattison New Member Introductions 4 03-22-2010 11:20 PM
jig for making exterior shutters djwarren New Member Introductions 0 10-28-2008 12:35 AM
Shutters Richard Swain Starting Off 2 06-02-2007 05:00 AM
