need help locating pic for template routing - Router Forums
 7Likes
post #1 of 16 (permalink) Old 06-23-2018, 03:27 PM Thread Starter
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Default need help locating pic for template routing
Sorry if this is a re-post but the forum kicked me out.
I need help locating the pic showing the correct way to route on a table top doing inside a template.
I found the one for hand-held but need the one for table top.
I know it's just the opposite. But it'll be clearer if he doesn't have to juggle it in his brain. And I can print it & post it in the shop
Thks
smitty
smitty10101 is offline
post #2 of 16 (permalink) Old 06-23-2018, 03:32 PM
post #3 of 16 (permalink) Old 06-23-2018, 04:33 PM
vchiarelli's Avatar
First Name: Vince
The easy way to remember, for me, when using a table top is to keep the bit to the right of the material/template and feed right to left
vchiarelli is offline
post #4 of 16 (permalink) Old 06-23-2018, 04:47 PM Thread Starter
First Name: smitty
@stick
got them----but the picture shows a hand held --and the "discussion" with the other party was for table use.
Somewhere (I believe it was you) there was a post (years ago) showing both hand held & table top.
I'm diligently searching my library of books and the web but so far no joy.
I was just hoping that someone had it on their fingertips---so I don't go completely nuts looking for it
where are Pat Warners archives when you need them?? Maybe we should resurrect him!!
post #5 of 16 (permalink) Old 06-23-2018, 07:05 PM
First Name: Reuel
Thks
smitty
Save the pictures published in link below. Add big arrows yourself by editing with PAINT software.
https://www.woodcraft.com/blog_entri...feed-direction
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #6 of 16 (permalink) Old 06-23-2018, 08:07 PM Thread Starter
First Name: smitty
@reuelt
got the link but no pics load
will try another computer in case I've set something on this one that's causing it to misbehave.
thks
smitty
post #7 of 16 (permalink) Old 06-23-2018, 08:25 PM
vchiarelli's Avatar
First Name: Vince
smitty: see my previous post - when routing on a table, don't think of the inside or outside edge. Feed it in the same direction you would feed a straight piece, with the bit to the right of the work piece, feeding from left to right.
See if this picture helps - the arrow designates the feed direction OF THE WORKPIECE
post #8 of 16 (permalink) Old 06-24-2018, 05:36 PM
MEBCWD's Avatar
This may help
Name:	Router Table Feed.jpg
MEBCWD is online now
post #9 of 16 (permalink) Old 06-24-2018, 08:13 PM Thread Starter
First Name: smitty
@MEBCWD
yes!! that'll work
thank you
Can I ask where you located it??
again thks
smitty
post #10 of 16 (permalink) Old 06-24-2018, 10:49 PM
MEBCWD's Avatar
@MEBCWD
yes!! that'll work
thank you
again thks
smitty
I looked for something online but did not find what I was looking for so I actually drew it in Aspire, my CNC software.
Stick486 likes this.
Need help locating Switch Key for Craftman Routing Center. tedvandyke Portable Routing 14 05-08-2017 02:36 AM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 08:31 PM
Table top display cse. derek willis Show N' Tell 16 04-13-2014 07:31 AM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 04:18 AM
