mistersixties - Router Forums
 2Likes
  • 2 Post By mistersixties
post #1 of 1 (permalink) Old 06-27-2018, 11:25 PM Thread Starter
Country: New Zealand
First Name: Ron
Default mistersixties
Hi Guys, Just to let you know - the problems i had with the Chinese T8 CNC Engraving Machine and how to fix them. The main problem was the software froze when the 24 volt spindle motor was switched on. The way to fix this problem is to solder a small value capacitor (number 104m) across the terminals of the 24 volt motor and 1 each of the same value from each terminal to the case of the motor. This acts to suppress the motor noise and stops the interference with the software. This worked for me, i hope this helps someone out there who may have the same problems as i did. Cheers Ron:
reuelt and RainMan 2.0 like this.
mistersixties is offline
