palm or lamintae router for sign making? - Router Forums
 22Likes
post #1 of 21 (permalink) Old 07-01-2018, 07:36 PM Thread Starter
bugsy57's Avatar
First Name: ERWIN
Default palm or lamintae router for sign making?
800W 30000RPM Electric Hand Trimmer Wood Laminate Palm Router Joiner Tool Device. would you all recommend this model router for sign making(letters)?..(see attached file)
Being depressed is no fun i should know because i had fun once!
bugsy57 is offline
post #2 of 21 (permalink) Old 07-01-2018, 08:30 PM
I know nothing about that router. It is a low end router and will probably get through a sign or three. Just don't expect a lot from it and when it does go out just toss it , you will probably get the $37.39 worth of use out of it.
Herb Stoops is online now
post #3 of 21 (permalink) Old 07-01-2018, 08:38 PM
a plunge based Colt would be a better way to go...
a full sized 1617n wouldn't hurt either...
bugsy57 likes this.
post #4 of 21 (permalink) Old 07-01-2018, 09:53 PM
A plunge base wourl be better. Even better would be one with a clear plastic base so you could clearly see the workpiece. A base with two knobs on it could be made of clear plastic. But in fact, that stuff is already available. The most important thing will be the plunge base, and this little router may not have one. It is very hard to start a sign by tilting the bit into the piece. It will want to run away and take out a lot of wood as it does it.
post #5 of 21 (permalink) Old 07-02-2018, 12:18 AM
Herb's comments about that router are pretty accurate. If you just want to try it first and see how it goes that might be a good way to start. Your profile says you have 20 years experience so even if you don't like sign making a better quality small router still has lots of uses. Some good choices are the Colt, Makita RT700, or a DeWalt 611, it being a bit larger and more powerful. All can be had with a plunge base which increases their usefulness. You can still use a much larger router too. I've made signs with 3 plus hp plunge routers.
bugsy57 likes this.
post #6 of 21 (permalink) Old 07-02-2018, 08:05 AM
Andrew_the_Celt's Avatar
Depends on how large and how deep you wish to incise the letters. If you're just looking for small, simple signage then a smaller router might suffice but they're limited in what they can do on other tasks.
A plunge router or dual base gives you more flexibility that a small (generally fixed base) router and higher amp motor can help if you're producing many signs, large ones or hogging out lots of material with something like a bottom bit or eventually want to make cabinets or other larger projects.
Larger units also are more useful for table mounting if you want to do pin routing to produce a lot of the same signs or signs with common looks from templates (like borders, outlines, etc. with custom lettering added to each.
Andrew_the_Celt is offline
post #7 of 21 (permalink) Old 07-02-2018, 10:34 AM
kp91's Avatar
First Name: Doug
I used 2 small laminate trim routers when I first carved signs by hand, each had a custom acrylic sub base that was much bigger than the original. The problem I had is I couldn't see the bit well through the small base of the router. I switched to a 1 1-2 horsepower fixed based router with a large acrylic sub base and that works a lot better for me. The opening around the bit allows me a better view of the cutting.
That router has a clear base, but the opening on the front isn't that big. You'll have to decide if you can see in there or not.
DesertRatTom and Herb Stoops like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #8 of 21 (permalink) Old 07-02-2018, 10:45 AM
CharleyL's Avatar
First Name: Charley
I think you will be much happier with a plunge base type router for sign making. The depth adjustment on the router in your photo isn't easily adjusted for depth accuracy or repeatability. I prefer my DeWalt DWP611 with it's plunge base for tasks like this. It also came with a fixed adjustment base, but I prefer to use the plunge base for sign making and other uses that require repeatable depth adjustments. I added the optional vacuum attachment to it so that the chips are removed efficiently when my eyes and nose need to be close enough to see the router bit cutting area, like if I'm hand guiding the router while routing a sign. I also have a DeWalt laminate trimmer with 4 different bases, but no plunge base. I would not use it for sign making as it's just not the best design for this purpose, but it does what it was designed for very well.
Laminate trimmers, like the one in your photo, are designed to trim the overhang of thin materials like the hard surface materials used on counter tops. In this use, they do not require precise depth settings, and the bits used either have a bearing guide or smooth pin on the bottom end of them to act as a follower guide. The side of the bit does the actual cutting and not the bottom end, so precise depth adjustment isn't necessary.
The laminate trimmer in your photo looks to me like it might be one of the cheap Chinese Laminate Trimmers, but you didn't say who made it. A friend bought one similar to this one from a local Chinese Import Tool store, and it burned up within 5 minutes of use. He took it back and got another. This second one lasted until part way through his next job before the bearings went bad in it. He now owns a DeWalt laminate trimmer and has been using it on many jobs over the past several years without any problems at all, and he will likely not have problems with it for years to come, if ever.
Charley
Central North Carolina
CharleyL is online now
post #9 of 21 (permalink) Old 07-02-2018, 11:40 AM
Gaffboat's Avatar
First Name: Oliver
Like Charley, I use a Dewalt 611 for my freehand sign carving, although I use the fixed base rather than a plunge. The router you show may work well enough, but Doug's comment about the small viewing area is the most critical problem with using it for sign carving. You need to be able to see the line you're following, and you also need as much light as possible. I actually modified my Dewalt housing, to create a large opening on the side opposite the normal viewing area, so I could see better, and get more light on my work. Tom pointed out another important factor: adding a larger clear base with handles makes it much easier to control the router while following your lines. I would suggest thinking about a better router if you are seriously wanted to get into sign carving. It may be tempting to start with this router to test the sign carving waters, but I suspect you may be frustrated and give up, not because you don't have the skills, but because your tool isn't the right one.
kp91 and Herb Stoops like this.
Gaffboat is offline
post #10 of 21 (permalink) Old 07-02-2018, 01:46 PM
I think a lot of people give up way too soon when trying something new. Practice, practice, practice is required to develop the ability to closely control whichever router you choose to use. I have a Colt with a variety of bases and it's nice, but I think the 611 is a little better for sign making, as is the Makita, which has gotten some strong endorsements when it first came out. The Colt is very nice, however, I think I might have chosen the Makita for things like sign making.
kp91 and Gaffboat like this.
What router for signs making JimofSC Sign Making 11 04-19-2015 09:16 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Palm Router for CNC kolias CNC Routing 2 11-10-2010 01:36 PM
Full-sized router or palm (trim) router for this job? LBrandt Portable Routing 5 08-06-2006 10:41 PM
