Bit won't go allthe way into collet - Router Forums
 5Likes
  • 5 Post By Cherryville Chuck
post #1 of 4 (permalink) Old 07-02-2018, 02:47 PM Thread Starter
First Name: Paul
Default Bit won't go allthe way into collet
I have a Ryobi R163 router and something happened to to the collet. First I had a lot of trouble getting the bit out of the collet. Then, when I finally got it out, I couldn't get any of my bits to go more than perhaps half an inch back in. I've removed the collet entirely, so that's not the problem. What should I do about it?
pwabrahams is offline
post #2 of 4 (permalink) Old 07-02-2018, 04:00 PM
You can try taking a thin bladed screw driver and spreading the slots apart. Whether that will last as a fix is questionable.You didn't tighten the collet down with no bit in it did you?
post #3 of 4 (permalink) Old 07-02-2018, 06:47 PM Thread Starter
First Name: Paul
Default Sorry, I removed the collet nut
Sorry, I misspoke (miswrote) in my message. I removed the collet nut, not the collet itself. I haven't yet tried to remove the collet itself. I don't know how difficult it will be to get the collet out.
post #4 of 4 (permalink) Old 07-02-2018, 10:14 PM
Lay the router on it's side with the base plate retracted enough to give you a clear shot at the collet and take a pin punch (not sharp on the end) and tap the side of the collet lightly where it's exposed. Rotate it a little after every tap. It sounds like you tightened the nut down with no bit in it which is something you should never do. If you are spinning the nut down on an empty collet do it by hand and the moment you feel the nut touch the collet stop!
Gene Howe, MEBCWD, TenGees and 2 others like this.
Collet bit problems NancyM New Member Introductions 8 10-18-2013 01:46 PM
Need help with broken collet and stuck bit on a brand new Hitachi M12VE. kracken41 General Routing 33 12-20-2012 06:27 PM
MY PC 7518 collet was junk, I replaced it with a Precision Collet what a difference. Bill Huber General Routing 0 09-25-2012 11:52 PM
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 09:25 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
