Burning smell - Router Forums
 4Likes
  • 1 Post By Cherryville Chuck
  • 1 Post By Nickp
  • 1 Post By Knothead47
  • 1 Post By radios
post #1 of 9 (permalink) Old 07-09-2018, 11:05 PM Thread Starter
Default Burning smell
Hey guys.. have a quick question. Have a 2hp router that I've had only about a year. Yesterday I smelled an electrical burning smell when I turned it on. Pulled out the brushes and one side was lopsided worn, the other was fine. Fixed the one. Still has the smell. Blew air through it to get out dust, no help. See sparks through the vents but it isn't running hot. Could this still be brushes, bearings or is the motor just about to burn up?
Thanks for any advice.
Rburgess0973 is offline
post #2 of 9 (permalink) Old 07-10-2018, 12:04 AM
Did you only replace the one, obviously damaged brush?
post #3 of 9 (permalink) Old 07-10-2018, 12:06 AM
The one smell that is the death smell is of hot varnish. If that's the smell and it hasn't quit yet then chances are good it will.
DesertRatTom likes this.
post #4 of 9 (permalink) Old 07-10-2018, 04:23 AM
replaced the brush or reshaped the old one???
what brand of router is it...
post #5 of 9 (permalink) Old 07-10-2018, 06:13 AM
First Name: Larry
Let us know what it is when you find it!
doglover85 is offline
post #6 of 9 (permalink) Old 07-10-2018, 06:29 AM
difalkner's Avatar
First Name: David
Welcome to the forum! When you get a minute go ahead and complete your profile with first name so it doesn't show N/a in the left panel. Your location is helpful, too.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 9 (permalink) Old 07-10-2018, 08:29 AM
Nickp's Avatar
First Name: Nick
A hearty welcome to you...
It's possible that there may still be some carbon in and around the commutator...do a good cleanup with a good contact cleaner.
Also...check the spring tension on the brushes...maybe they are weak and the brushes are bouncing/floating.
Did you replace the bad brush or "fix it"...? There must be a reason it went lopsided... Make sure you have the correct brushes.
If you fixed it, it may just need to wear in a radius to match the commutator...check the bad brush again.
And maybe it might be a good idea to swap the hot and cold brushes...
I would get new brushes just to make sure...
Good luck
Herb Stoops likes this.
Nick
Nickp is offline
post #8 of 9 (permalink) Old 07-10-2018, 05:30 PM
Knothead47's Avatar
Use this as an excuse to buy a new router.
John T.
Knothead47 is offline
post #9 of 9 (permalink) Old 07-12-2018, 02:28 AM
First Name: martin
you might have contaminated brushes, replace them.. I'd also sand paper the commutator with 220 grit, lightly, just make it clean. check that the gap between the copper poles have a groove in them, if not that can be fixed with a hacksaw blade that has the teeth ground flat on the sides, don't go too deep.. if this don't work, you might have a bad winding, you can check this by, with the router unplugged, connect and ohmmeter onto the 2 brushes, and make sure that you get a low ohms reading everytime the copper strips on the commutator align with the brushes when you rotate the shaft, if you get a high reading, that means a winding either has a bad connection, or burned out..
Cherryville Chuck likes this.
radios is offline
Burning while ripping on the TS hawkeye10 Tools and Woodworking 29 02-18-2018 11:24 AM
Smell sense changed by sawdust? TomF Tools and Woodworking 12 05-24-2010 10:23 AM
New Here and Contemplating Burning as a Hobby williamyoung Pyrography and Carving 10 12-01-2009 03:17 PM
Burning Bits Implementitis General Routing 15 11-12-2009 10:49 AM
Knight and Castle Wood Burning kcortese Pyrography and Carving 19 10-26-2009 06:33 AM
