Dumb question..? Sub base - Router Forums
 16Likes
post #1 of 14 (permalink) Old 07-11-2018, 03:17 PM Thread Starter
username1's Avatar
First Name: Art
Default Dumb question..? Sub base
I just bought a Rousseau base plate for the table i am building.
I hear the term "sub base" and I don't know if it refers to the base plate that came on the Router, and if I am supposed to mount the Rousseau plate over that one or remove it and mount the Rousseau plate alone?
I assumed that the Rousseau plate replaced the old one, but then the term "sub-base" threw me...
"You kids get offa my lawn!"
username1 is offline
post #2 of 14 (permalink) Old 07-11-2018, 03:28 PM
It usually refers to the black phenolic plastic one attached to the base. You need to take it off to mount the Rousseau or most other bases. In some cases you may need to find longer machine screws to attach the new one with as they are thicker than the black plastic one that comes on the router.
MT Stringer and Herb Stoops like this.
post #3 of 14 (permalink) Old 07-11-2018, 04:06 PM
vchiarelli's Avatar
First Name: Vince
@username1 - Welcome to the forum Art, and no, there are no "dumb" questions. As Chuck said, the sub-base refers to the base that came attached to the router. If your Rousseau plate isn't drilled to mount to your router, use the sub-base to mark out the location for the holes.
Cherryville Chuck likes this.
vchiarelli is offline
post #4 of 14 (permalink) Old 07-11-2018, 04:09 PM Thread Starter
username1's Avatar
First Name: Art
Ok, that's what I thought. Thanks!
post #5 of 14 (permalink) Old 07-11-2018, 05:43 PM
If as Vince says you need to drill the holes in the Rousseau to mount to your router then start a new thread asking about that. There are some tips we can give you to mount it correctly. You want to get it centered to the router armature so that you can use it with guide bushings.
Herb Stoops likes this.
post #6 of 14 (permalink) Old 07-11-2018, 07:16 PM
JOAT's Avatar
First Name: Theo
Very obvious you have never worked with military recruits. Yes, there ARE dumb questions.
JOAT is online now
post #7 of 14 (permalink) Old 07-11-2018, 07:55 PM
But not on this forum.
post #8 of 14 (permalink) Old 07-11-2018, 08:27 PM
vchiarelli's Avatar
First Name: Vince
That may be the case, but, every question asked is a teaching opportunity. I have found that there are more dumb answers than dumb questions.
gmercer_48083 and RÖENTGEEP like this.
post #9 of 14 (permalink) Old 07-11-2018, 10:10 PM Thread Starter
username1's Avatar
First Name: Art
... There are some tips we can give you to mount it correctly. You want to get it centered to the router armature so that you can use it with guide bushings.
Just came in from finishing the job of mounting plate to Router and also mounting plate in Table.
Bought both the centering kit and the table install kit. In a rare instance, I actually read the instructions, measured-twice-and-cut-once, and both jobs came out almost 100% dead on. (this rarely happens!)
The one hole I did mis-align was the access hole for fine adjusting above the table, but it still works.
First projects:
Table insert
Perfect Dado Jig
Circle Jig
Finger Joint Jigs
post #10 of 14 (permalink) Old 07-11-2018, 10:12 PM
JOAT's Avatar
First Name: Theo
Would you count, "What the #$%^ were you thinking when you asked that?", as a dumb answer, or as a teaching opportunity? Hehehe Believe, me there are days when that is the best answer possible. Than you go and bang your head against a wall. Ah, the good old days, great times with great days.
JOAT is online now
Bosch plunge router base problem gwizz General Routing 20 03-16-2017 07:02 PM
Bosch Colt Plunge Base PR011 Question harpone Guide Bushings and Templates 2 11-21-2016 11:03 AM
Dumb table saw question Bill from Indy Tools and Woodworking 19 08-17-2012 03:39 PM
dumb question AaronRC4 Table-mounted Routing 22 03-10-2012 09:42 PM
Making your own base plate - Question?? mountain monkey Guide Bushings and Templates 2 09-05-2008 11:23 AM
