Router Bits Off-Centered - Router Forums
 7Likes
post #1 of 44 (permalink) Old 07-22-2018, 06:31 PM Thread Starter
Alt
Alt's Avatar
First Name: Alt
Default Router Bits Off-Centered
12 Amp Craftsman Professional Plunge Router
Model number: 315.248851
I'm having problems with a second hand router. I think the main spinning shaft is bent, but I wanted to get another opinion before wasting time and money on parts. It's not significant, but you can see the off-centeredness if you watch the bits come to a stop. I tested the same bits on my drill press and they spin perfectly centered, so I don't think its them.
Does anyone think there could be something I'm missing, or perhaps an adjustment I can make? Or if not, which parts are probably causing the wobble. I've attached a GIF of the wobble.
Thanks!
Alt
Alt is offline
post #2 of 44 (permalink) Old 07-22-2018, 06:49 PM
welcome N/A..
it's called runout more often than not caused by a faulty bearing...
post #3 of 44 (permalink) Old 07-22-2018, 07:22 PM Thread Starter
Alt
Alt's Avatar
First Name: Alt
So I should start by replacing the bearings?
Alt is offline
post #4 of 44 (permalink) Old 07-22-2018, 07:32 PM
no..
evaluate...
who made the router???
post #5 of 44 (permalink) Old 07-22-2018, 09:22 PM Thread Starter
Alt
Alt's Avatar
First Name: Alt
Craftsman. I haven't been able to find this specific model anywhere online.
Alt is offline
post #6 of 44 (permalink) Old 07-22-2018, 09:56 PM
315.xxx makes it a Ryobie...
the bearing will be a tough find... what's in it is proprietary...
a wholesaler may have it...
so now N/A let's introduce you to the world of Bosch...
picking out a tool(s)...
1st and most important, look to the company...
evaluate their CS and will they step up to the plate should there be issues...
see if they have a planned obsolesce program in force... as does craftsman...
what will the company and their product do for me...
try to figure out if they will respect me in the morning...
no sense in buying something that can't be fixed a few years later...
next the product...
quality..
will it have a long productive life...
will it do more than I need it to....
is it a good value...
will it protect my bottom line...
will it go the extra mile...
will it go obsolete or become disposable in short order...
tools that don't cut the mustard, suffer down time, hurt production and the bottom line need to left on the store shelf...
Online reviews...
not too much...
read a few too many that my VOE said other wise...
I prefer to use and abuse different brands and evaluate them myself and I pay attention at large job sites as to who has what and what, if any, issues they are having......
the testers should eval a tool and then put it in production mode for a few years and then do another eval..
Bosch fills the bill and then some...
2nd to none CS and support...
real work horse...
last long time...
protects my bottom line...
WHY I LIKE BOSCH...
2nd to none CS/TS support (American based) that's absolutely painless... They even support their tools that have been discontinued really well...
Their tools are real work horses...
planned obsolesce isn't an issue w/ them and come w/ less all around grief...
they make tools that last a very long time... decades of hard heavy use..
they make tools that protect the bottom line... this I like...
Besides they being comfortable to use routers, they are much more feature rich, mighty fine soft start, way better fine depth adjustment, quality collets, and so much more...
I think and believe Bosch to be an excellent outstanding company...
Keep in mind, that saving some money now just may cost you more down the road... Do yourself a huge favor and get a Bosch...
Bosch consistently scores high in/on all categories of quality, CS/TS, reliability and support, and they are as close as a phone call and your mail box...
http://www.routerforums.com/featured...machinery.html
post #7 of 44 (permalink) Old 07-22-2018, 10:21 PM
Hypnotoad's Avatar
First Name: Phillip
Years ago I used to have to go find bearings for alternators, I would go to a bearing shop with the old bearings and they would simply measure the inside, outside and depth and get me the same bearing. If you're wanting a new router Bosch would be a good choice, so would Makita and Hitachi if you want a plunge router.
Tight fisted old so-and-so!
Hypnotoad is offline
post #8 of 44 (permalink) Old 07-23-2018, 12:07 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
A custom sized bearing is a very rare thing.
tool manufacturers use bearings made by bearing manufacturers.
If you can feel ANY side to side movement on the bit then its a bearing problem.
If you can disassemble the machine to get the bearing out you have a 99.99% chance of buying another bearing to fit, and it will be pretty cheap compared to a new machine.
But buy two because the one at the other end will be in the same state.
sunnybob is offline
post #9 of 44 (permalink) Old 07-23-2018, 12:46 AM
I would think that if the bearing is so bad that you can see the runout then you should also be able to hear and feel it. Usually when they get that bad they get noisy and vibrate. If you take the collet nut off and hold something with a sharp point across the base, touching the armature shaft, then when you spin it (by hand) there will be a gap when the armature is to one side if it's bent. At that speed the bearing won't be an issue unless it's really sloppy. When I say spin it I'm talking about maybe 1 turn in 5-10 seconds while you watch carefully to see if a gap becomes visible.
post #10 of 44 (permalink) Old 07-23-2018, 07:10 AM
Danman1957's Avatar
Welcome Alt,
Welcome to the Forum. What part of our great country do you call home.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
MCLS Router Bits sreilly Router Bits - Types and Usage 69 09-09-2019 11:33 AM
Router speeds for different bits and types of wood judasentinel General Routing 15 05-21-2018 12:43 PM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Router bits needed for Leigh Dovetail Jig D4R Llewellyn New Member Introductions 11 08-13-2012 03:04 AM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
