Help, i want to play with my new toy. - Router Forums
post #1 of 9 (permalink) Old 07-31-2018, 10:59 AM Thread Starter
Default Help, i want to play with my new toy.
So a friend of mine just retired and sold his house, and got rid of a craftsman router, 315.175040, 110-120 Volt, 60hz,8.0amp. It worked great when i grabbed it from him yesterday, but today i decided to run a test piece through it and it shut off on its own. After trying to adjust it to see what would make it run again, i found that it will only run if the shaft locking mechanism, (in the unlock position) was pressed down a bit, (im assuming so it will make electrical contact some how) Any suggestions on a fix? Ive already tried clamping it in position once already and that didnt work.
-Mark
Mark Manning is offline
post #2 of 9 (permalink) Old 07-31-2018, 01:48 PM
Hi Mark and welcome. You might try blowing some compressed air into the switch and see if that helps. If not you'll probably need to take the top off and as I recall it's a little tricky. I think you have to reach in with a Phillips screwdriver and undo the shaft lock switch handle to get the top off but it's been a while since I took one apart. Hopefully it's something visibly wrong when you get in there. I don't know if it's a good idea to bypass that switch if you can't figure it out. When the switch is in the locked position it cuts power to the router so that you can't start it up with the lock engaged if I remember right. If you bypassed it you would have to be fastidious in unlocking right away when the bit is changed and never walking away from it in the locked position. I forgot once and was lucky it had that feature.
post #3 of 9 (permalink) Old 08-01-2018, 12:22 AM
old55's Avatar
First Name: Ross
Welcome to the forum Mark.
Ross,
old55 is online now
post #4 of 9 (permalink) Old 08-01-2018, 07:41 AM
First Name: Gary
Here's the owners manual.
File Type: pdf Craftsman Router315175040_owners_manual.pdf (1.79 MB, 25 views)
gmercer_48083 is offline
post #5 of 9 (permalink) Old 08-01-2018, 08:58 AM
sreilly's Avatar
First Name: Steve
Welcome Mark.
sreilly is offline
post #6 of 9 (permalink) Old 08-01-2018, 08:56 PM Thread Starter
Just took off the cap on top and blew some comressed air into it and it started working without having to hold the spindle lock in position, but once i brought it home and tried it out again, it stopped working without assistance. Might have to replace something, there is no defacing of this product and i found no damage inside that i could see.
post #7 of 9 (permalink) Old 08-01-2018, 08:56 PM Thread Starter
Thank you!
post #8 of 9 (permalink) Old 08-02-2018, 12:03 AM
If there is a spring that is supposed to hold it in position it may be weak. Getting parts for old Sears routers isn't easy. Ereplacement parts is the best possible source but most parts are listed as N/A, obsolete, or not available.
post #9 of 9 (permalink) Old 08-02-2018, 03:41 AM
Hypnotoad's Avatar
First Name: Phillip
It wouldn't hurt to try some contact cleaner:
https://www.wd40specialist.com/products/contact-cleaner
Please note this is nothing like regular WD40 which should never be used as a contact cleaner or on most things.
Tight fisted old so-and-so!
Hypnotoad is offline
toy trains parts and more paduke Tools and Woodworking 7 01-04-2017 11:42 AM
Finish for Grandson's Toy Box chuckgray The Finishing Touch 26 11-05-2015 08:29 AM
Pat's Toy Box - Bigger than the last one MT Stringer Show N' Tell 16 07-13-2015 09:59 AM
Toy Box for Grandson oldwoodenshoe Show N' Tell 11 06-14-2014 09:53 AM
