Vibration - Router Forums
 8Likes
post #1 of 21 (permalink) Old 08-05-2018, 08:47 AM Thread Starter
pusserboy's Avatar
First Name: Stuart
Default Vibration
Hi All
I would like to know what causes vibration sometimes when cutting the end of the wood and how to avoid it
Thanks for the information
Stuart
pusserboy is offline
post #2 of 21 (permalink) Old 08-05-2018, 08:57 AM
Gene Howe's Avatar
First Name: Gene
Originally Posted by pusserboy View Post
Hi All
Stuart
Which tool. If it's a router, which router? What bit specifically? Need more info.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 21 (permalink) Old 08-05-2018, 09:26 AM
planer or table saw???
post #4 of 21 (permalink) Old 08-05-2018, 09:56 AM Thread Starter
pusserboy's Avatar
First Name: Stuart
Router Table Bosch, Rail Bit
Stuart
post #5 of 21 (permalink) Old 08-05-2018, 10:32 AM
are you sure it isn't chatter???
MEBCWD likes this.
post #6 of 21 (permalink) Old 08-05-2018, 11:12 AM Thread Starter
pusserboy's Avatar
First Name: Stuart
Sticks
I'm new to all the terms but it could be chatter.
Stuart
post #7 of 21 (permalink) Old 08-05-2018, 11:39 AM
what does your cuts look like???
post #8 of 21 (permalink) Old 08-05-2018, 11:40 AM
got any pictures...
post #9 of 21 (permalink) Old 08-05-2018, 12:50 PM
Is it the workpiece that's vibrating a little up and down as it passes the blade? Or the saw itself vibrating? The first is more like chatter. Check the blade, tooth by tooth, any broken, chipped or out of line. Is the board twisted slightly (laying on the flat table, it rocks slightly side to side), or otherwise not straight and flat, then that could cause a problem.
MT Stringer likes this.
post #10 of 21 (permalink) Old 08-05-2018, 12:59 PM
Gene Howe's Avatar
First Name: Gene
Not sure what a "rail" bit is. What size is the Bosch motor? Is it variable speed?
You could be taking too big/deep of a cut. Also, the end grain should be cut first. Then, the long grain cut will take away any tear out.
harrysin and graeme.c.payne like this.
Gene Howe
Snowflake, AZ
vibration on gantry y exies cover. Abid CNC Routing 1 07-16-2014 09:12 PM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-19-2014 11:41 PM
Router Vibration Diagnosis 320.17540 The Cyclist General Routing 8 12-05-2011 07:29 AM
Porter Cable 890 vibration and recall rlp_rlp General Routing 3 03-22-2011 08:55 PM
Power tools and vibration Mike Tools and Woodworking 5 01-14-2005 11:36 AM
