Ryobiy R500 Router - How to Install Bit - Router Forums
 4Likes
  • 2 Post By Hypnotoad
  • 1 Post By Cherryville Chuck
  • 1 Post By CharleyL
post #1 of 8 (permalink) Old 08-06-2018, 08:45 PM Thread Starter
Default Ryobi R500 Router - How to Install Bit
Hi. I received a Ryobi R500 plunge router from my grandfather, but it didn't come with a manual and I can't find one on the internet anywhere. My main question is how to install a router bit. I own a Craftsman router that has a collet that you insert the bit and then tighten the nut to secure the bit. However, the collet on the Ryobi doesn't look anything like the Craftsman. It doesn't appear to be missing anything when I compare it with pictures online, but I also don't see any nut or allen key screw to secure the bit. Can anyone explain how the collet on this router works?
Thanks in advance,
John
johnway2 is offline
post #2 of 8 (permalink) Old 08-06-2018, 10:23 PM
Hypnotoad's Avatar
First Name: Phillip
Always do this or anything when tinkering with a power tool with it unplugged.
You need to use two wrenches one that fits the flats of the collet at the opening and one that fits the flats of the collet on the spindle. I take it the Craftsman has a spindle lock. The Ryobi you have doesn't so the wrench that goes on the flats on the spindle keep it from turning like the spindle lock which is my badly drawn black wrench. So while holding the spindle still with the wrench on the spindle flats (the black wrench), you tighten with the other wrench on the flats near the opening of the collet which is my badly drawn red wrench, clockwise to tighten and anti-clockwise to loosen.
Hope this gives you an idea of how it works.
Rogerdodge and Herb Stoops like this.
Tight fisted old so-and-so!
Hypnotoad is offline
post #3 of 8 (permalink) Old 08-06-2018, 10:39 PM Thread Starter
Perfect! Thank you.
johnway2 is offline
post #4 of 8 (permalink) Old 08-07-2018, 12:07 AM
Hi John and welcome. Exactly what Phillip said. That collet looks identical to my Hitachi M12V and also an older Makita model but both of those had built in spindle locks. Personally I prefer the two wrenches method.
Herb Stoops likes this.
post #5 of 8 (permalink) Old 08-07-2018, 09:59 AM
CharleyL's Avatar
First Name: Charley
My DeWalt routers all came with spindle locks too, but can still be used with two wrenches. I ordered additional wrenches and always use two wrenches on them. I hate the spindle locks, since I think I'm able to tighten the collets better using two wrenches.
@phillip ,
The Ryobi wrenches for your router collet are just thin versions of metric open end wrenches, but you can likely use just the common automotive style wrenches that are readily available. In most cases, they will work just as well.
Charley
Central North Carolina
CharleyL is online now
post #6 of 8 (permalink) Old 08-07-2018, 07:31 PM
Hypnotoad's Avatar
First Name: Phillip
@phillip ,
Charley
My Bosch and Makita have spindle locks and no way to use two wrenches, I used to have a Hitachi with the two wrench system like the OP's Ryobi but prefer the one wrench especially when mounted in a router table. I often wonder though if the spindle locks will fail eventually.
post #7 of 8 (permalink) Old 08-07-2018, 10:14 PM
Makitas will fail. I used one in a factory that had and one new member was here who had the problem with his Makita. I often find it hard to get the leverage on the wrench while trying to hold the spindle lock on and the Hitachi one gets in the way of the wrench.
post #8 of 8 (permalink) Old 08-08-2018, 09:20 AM
roxanne562001's Avatar
First Name: Roxanne
Hi John Use 2 wrenches like Phil said. I like the 2 wrench system. I made a set of offset thin wrenches for my Hitachi M12V to work better in the table mounted set up ,it uses the same type system. I cut the wrenches out of cold rolled plate steel and then case hardened them. I am on the road setting up at fairs so I can't send you a picture. I will be back home in a few weeks if you like I can send you a picture of the wrenches I made.
roxanne562001 is online now
Build an economy table top and install a mounting plate Mike Table-mounted Routing 93 01-15-2016 11:52 AM
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 15 09-23-2014 09:15 AM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-20-2014 12:41 AM
Sears router bit description gary smyth Router Bits - Types and Usage 4 07-01-2011 06:15 PM
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 10:46 AM
