Horizontal boring/routing chatter - Router Forums
post #1 of 2 (permalink) Old 08-07-2018, 08:56 PM Thread Starter
Default Horizontal boring/routing chatter
Hi, i have a grizzly g0540 hor. boring machine i want to use for routing mortises with router bits. it works pretty good but would it work faster with less chatter if i put a small router in place of the 3750rpm motor that it has now. thanks for any info
joe123 is offline
post #2 of 2 (permalink) Old 08-08-2018, 09:21 AM
MEBCWD's Avatar
The boring machine is not fast enough to run router bits, I would replace the 3750rpm motor with a router.
MEBCWD is offline
Power Feed vs. Horizontal Table wbrisett Table-mounted Routing 4 01-03-2014 01:49 PM
horizontal routing Missouri Boiler General Routing 4 08-07-2012 04:35 AM
MLCS Horizontal Router Table Update bobj3 Table-mounted Routing 4 01-24-2012 09:41 AM
Horizontal router table matt1710 Table-mounted Routing 15 05-02-2011 06:31 AM
Raised Panel Vertical or Horizontal Sets? WoodyRon Router Bits - Types and Usage 8 11-24-2007 02:54 PM
