Tongue and Groove question - Page 4 - Router Forums
 38Likes
post #31 of 62 (permalink) Old 09-01-2018, 09:26 AM Thread Starter
First Name: Dave
in this case.. more is better...
please don't think minimum...
I was considering the depth of cut of the slot bits that I have. In the case of a spline here I can see the longer the better.
DaninVan likes this.
"It's just a hardened oz or two of metal, sharpened to a razor edge, spinning at 24,000 rpm.....what could go wrong?"
adot45 is offline
post #32 of 62 (permalink) Old 09-01-2018, 09:36 AM
what slot ''bits'' do you have??
post #33 of 62 (permalink) Old 09-01-2018, 09:59 AM Thread Starter
First Name: Dave
It looks like the 1/4" slot cutter from my T & G set has got the deepest cut...1/2 inch
But if I knew exactly the bit for the job, I could let my fingers do the walking...
adot45 is offline
post #34 of 62 (permalink) Old 09-01-2018, 12:41 PM
get yourself a slot cutting set... or piece together as you see fit...
w/ the right bearing you can go up to 13/16'' deep..
Freud, CMT and Whiteside make the best stacked slot cutters...
also you can install smaller dia bearings for deeper cuts or still larger bearings for shallower slots... this takes additional accessory bearings sized individually or from a set...
Router CNC | Replacement Parts | Ball Bearings (open the sub links)
Router CNC | Joinery | Stacked Slotting Set
3 Wing Slot Cutter Set
CMT 823.001.11 15 Piece Slot Cutter Router Bit Set
https://www.whitesiderouterbits.com/...r&type=product
what you can do...
in operation...
post #35 of 62 (permalink) Old 09-01-2018, 12:51 PM
I defer to Stick and the other guys that do a lot of this, Dave, my background was residential construction, not cabinetmaking. This is relatively new to me also (15 yrs).
I love this Forum...I've learned so much from the other members here. Something new every day.
adot45 likes this.
DaninVan is offline
post #36 of 62 (permalink) Old 09-02-2018, 01:59 AM
First Name: Randy
Same here, but monthly. Tons of good advice. I'm a total newbie to routing. I've used em, I've trued up edges, splined together flooring planks, and other flooring projects requiring a router.
I've just never been trained or told how to. I've learned by seat of the pants.
..................I'm a bit off topic.
.....carry on.
ranman is offline
post #37 of 62 (permalink) Old 09-02-2018, 02:19 AM
"..........I'm a bit off topic."
-Randy
Welcome to the club!
-Dan
DaninVan is offline
post #38 of 62 (permalink) Old 09-02-2018, 02:24 AM
First Name: Randy
Thanks, DaninVan.
ranman is offline
post #39 of 62 (permalink) Old 09-02-2018, 02:45 AM
No need to be formal, Randy, Dan's good. The 'in Van(couver)' is where I used to live. Now I walk across the street to the beach and look across the straight to the city. Don't miss it.
adot45 likes this.
DaninVan is offline
post #40 of 62 (permalink) Old 09-02-2018, 08:35 AM Thread Starter
First Name: Dave
.....carry on.
Welcome to the fray, i'd say you are right on topic.
As for router skills, you see I only know enough to get into dilemmas.
No better place to learn than here.
Was also glad to learn Dan doesn't live in a van.......
adot45 is offline
Tongue and Groove width nrudnick Router Bits - Types and Usage 12 05-22-2017 08:00 AM
Howdy! and a tongue and groove question rickbob New Member Introductions 8 12-03-2010 02:03 PM
Tongue & Groove Ceiling Question wyatt earp Project Plans and How To 10 04-06-2010 09:26 AM
Spline vs. Tongue & groove wanart General Routing 1 02-28-2006 07:22 AM
Tongue and groove bits archer_456 General Routing 4 02-18-2005 06:51 AM
