Router as a joiner? - Router Forums
 9Likes
post #1 of 19 (permalink) Old 09-01-2018, 02:51 PM Thread Starter
Knothead47's Avatar
Question Router as a joiner?
After several years of dropping hints by SWMBO, I have finally got it in my head to start on a dining room table for her. I scored a large quantity of pecan in various widths and thicknesses. I talked with a guy at the local VA clinic and he gave me some tips on how to begin planing the boards. After planing, can a router be used to smooth the edges f or joining? Might use dowels for joining and gluing. Your advice and experience is most welcome.
John T.
Knothead47 is offline
post #2 of 19 (permalink) Old 09-01-2018, 03:37 PM
where have you been John????
chiefifd32 likes this.
post #3 of 19 (permalink) Old 09-01-2018, 03:41 PM
go to the head of the class...
skip the dowels and do it w/ splines...
use a slotting cutter to cut the spline slots.....
harrysin and MEBCWD like this.
post #4 of 19 (permalink) Old 09-01-2018, 03:42 PM
Gene Howe's Avatar
First Name: Gene
Sure. Get a good straight edge...Mdf, ply etc....clamp it to the work leaving a smidge showing and, use a top bearing pattern bit.
Or, use the router table. Set the bit for a 16th or less cut and, bring the out feed fence forward to be flush with the cutter. Use a straight edge to insure it's flush.
Or, simply run the work on edge through the planer....if it's narrow enough. That's my go to method.
Edit...Stick beat me to it...I think. I can't read his pdf on this little kindle screen. But, I surely agree about using splines instead of dowels....or biscuits, for that matter.
harrysin likes this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #5 of 19 (permalink) Old 09-01-2018, 03:48 PM
you know.. dowels over time loosen all on their own...
you make through splines as well as blind...
you do bread boards on your table and you can do through splines...
splines help tremendously w/ alignment, strength, stability, and are easy to do...
MEBCWD likes this.
post #6 of 19 (permalink) Old 09-01-2018, 04:03 PM
Gene Howe's Avatar
First Name: Gene
I make my splines from hard board and, stop the slots so it doesn't show. I don't bother to conform the splines to the rounded ends of the slot. Why bother? The spline is only for alignment anywho.
Gene Howe
Snowflake, AZ
post #7 of 19 (permalink) Old 09-01-2018, 04:09 PM
two threads that will do you good...
https://www.routerforums.com/general...-question.html
https://www.routerforums.com/router-...n-project.html
post #8 of 19 (permalink) Old 09-01-2018, 04:12 PM
Baltic birch make for premium splines...
the spline is way more than just alignment..
Gene Howe and MEBCWD like this.
post #9 of 19 (permalink) Old 09-01-2018, 06:02 PM
Gene Howe's Avatar
First Name: Gene
True enough, Stick. BB would certainly add stability to an edge joint...if that's needed. My builds are small enough to not need the extra stability. But, an alignment spline is well worth the time. And hard board is cheap.
I did build a 9' long, 30" wide, 2" thick bar top about 20 years ago. Had 2 hard board splines. Last time I was in that place, last year, it was solid as it ever was. But, aside from one end, it was fully supported by the compartments below.
Gene Howe
Snowflake, AZ
post #10 of 19 (permalink) Old 09-01-2018, 08:57 PM
John; years ago I took a router course and the instructor had a slightly different take on the joint thing. He pointed out that if you have the two boards clamped in their proper location against each other and run your router, with a straight bit, down the joint the match will be perfect. Mirror images...doesn't matter if the line isn't perfectly straight.
It's the concept here, not the details; obviously this concept can be refined to a lot of different variables. The point is that the bit is perfectly round anything on one side will be perfectly matched on the other side.
Note; this is for freehand routing...not really applicable to table routing. Those adjustable dadoing jigs that so many members have built would be perfect for this app.
One thing for sure, the bit has to touch both edges at the same time, but you could leave a slight gap between the clamped boards. Obviously less than the bit diameter.
Gene Howe likes this.
DaninVan is offline
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Using a Router as a Joiner asrubin Table-mounted Routing 18 03-26-2010 04:35 PM
