Lap joint size - Router Forums
 2Likes
  • 1 Post By ranman
  • 1 Post By Cherryville Chuck
post #1 of 4 (permalink) Old 09-04-2018, 11:10 AM Thread Starter
First Name: Randy
Default Lap joint size
Are there some sort of standard dimensions for lap joints based on material thickness?.......... such as 1/2 the thickness?
sreilly likes this.
ranman is offline
post #2 of 4 (permalink) Old 09-04-2018, 11:47 AM
Half the thickness makes a lot of sense for the simplest reason that it means the machine setup is the same for all pieces. The 'KISS' principle in all its glory!
If you want to complicate your life you could go with this...
Woodwork - Bridle Joint information and Pictures
DaninVan is offline
post #3 of 4 (permalink) Old 09-04-2018, 02:32 PM
That's the secret. The closer you get to the middle, the better the joint will look, otherwise you'll have to sand, sand, sand, sand, sand to even it up. Get Terrie Noll's "Joint Book" for the last word on all kinds of joints. I'll be using lap joints to make stage scenery flats, and hitting the half way point precisely is important when you have from 6 to 8 joints per flat. You don't want to do much hand work. Glue on a lap joint will make it almost impossible to break.
A video I saw a couple of years ago had the builder cutting to the half way mark with a Japanese pull saw, and using that line to guide the router. Flats are made of soft pine so he just plows through, but with hard woods, you'd want to take off layers.
I saw a recent post that showed a very large mortising bit that was just for this kind of flattening, but I can't find it just now.
post #4 of 4 (permalink) Old 09-05-2018, 01:05 AM
Like Dan said, once you fine tune your setup to take off half the thickness you can make good time and you also don't have to worry about matching A to B. All pieces are the same.
Herb Stoops likes this.
The difference between a box joint and a finger joint bit Mike Router Bits - Types and Usage 6 09-08-2014 01:21 PM
Groove and Tennon Joint Construction neville9999 General Routing 3 11-19-2013 10:15 AM
Router bits for a rule joint davidaoh35 New Member Introductions 2 10-05-2013 05:04 AM
Lap Joint Jig Technogramps New Member Introductions 5 07-16-2012 02:47 AM
need half lap joint jig DJeansonne Jigs and Fixtures 11 08-17-2009 09:27 PM
